Question about Sharp XR-32X Projector
Abnomal reverse picture
I have give my projector for service techanician was left the wire of fan which adjoining hood lens he was starting projector so many times but result was that projctor went into safe mode and power of ,he was doing several timesthe result is that projector burn its green filter after that projector shows red and blue images ok when green gun is off, when we started three gun stamounsly we get abnormal picture and we start only green gun than get negitive picturepl. give us solution
  • 2,237 Answers
If it was the fault of the technician, they are responsible for the repair. if the green filter is bad, it needs replacing.
Posted on Aug 19, 2009
Can't get slide projector to focus with lens in projector
Check the lenses inside the lens tube and see if they are loose or out of place
Feb 05, 2014 | Kodak 4200 Slide Projector
Just got a hanimex sr9000 projector but while running film in reverse it just went dead light and all had to pull bits of trapped film out can i make it work again
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. any questions, feel free to contact me have a nice day! Jerry Lampdeng Limited
Nov 10, 2013 | Epson ELPLP41 EB S6 Lamp
I have a screenplay 5000 the projector comes on but shows no picture,also it makes noises coming from the front left side
if you are behind the projector and it is facing away from you then it could be the lamp blower under the power supply which would be on the right side rear, or one of the 2 fans on the right side. now if you are facing the projector the fan on the right would be the lcd blower fan. you need to make sure your lamp is even lit and then post your problem. this can be done by looking into the lens from the side. a more accurate description of the problem can better help me.
Jun 20, 2010 | InFocus ScreenPlay 5000 Multimedia...
Abnormal picture
if it's an xr-32x (as it shows on this pic), it's a dlp projector, not an lcd. therefore no green filter. it has only a colorwheel and a dmd chip to affect the color. if it's not an xr-32x, and it's an lcd projector, replace the green filter. sharp sells the parts for the optical engine. but if it was your service tech that did it, have them replace it.
Jul 28, 2009 | Sharp XR-32X Projector
Infocus x1a fan replacement
to remove the fan: remove the 8 screws from the bottom of the projector (4 silver, 4 inset and brass) and the 2 screws from the back. pull the back from the bottom, but use a small flat-head screwdriver to release the tabs seen through the topmost vent of the back. once off, unplug the speaker wires on the right and the cable harness on the left. pull the top off while pulling the front off from the bottom. remove the wire harnesses from the power supply board and the ground wire from the power input board. take the 4 screws off of the power input board and the 4 or 5 screws from the power supply board (and 1 center clip) and remove. take out the 4 or 5 screws from the metal shield and remove shield. now you can unplug the fan that need replacing and access the 2 screws holding the fan in. remove fan and replace with a like fan. since the fan speed is not monitored, if you can find one that's the same size, power, and plug size, use it. otherwise, contact an infocus service center and ask them for infocus part # 526-0192-00. reverse instructions to put it back together. but you must remove the front from the top case, put the top on first, plug the speaker and left harness in, then put the back and front on. wasn't that fun?
Jun 02, 2009 | InFocus X1A DLP Slide Projector
Optoma DV10 projetor suddenly started made popping sound
hi,
Please Check and service the fans and the Air filters. then check again. In case the noise still comes then service the fans or replace accordingly. By complete service of projector, this will work.
Rave services
Jan 12, 2009 | Optoma MovieTime DV10 Multimedia Projector
Short picture time when starting Optoma HD72 projector
Mine did the same thing. The bulb is used up...replace the bulb. That fixed mine, working great again.
Oct 05, 2008 | Optoma HD72 Multimedia Projector
Sanyo Multimedia Projector PLC-XT25L
Click here to download the user's manual. Go to page # 50 if you are seeing the image on the right side of the screen.
Jul 18, 2008 | Sanyo PLC-XT25L LCD Projector
Hi sheridan1,
buy one from an infocus service center. they're under $20 (because it has a 16:9 ratio). but to replace it, you have to remove the top, front, and rear panels. between the lamp and the lens is the colorwheel. carefully remove the 2 screws holding it on and set it aside. the ribbon cable is still attached, so you have limited space. remove the screws holding the tunnel clamp. remove the clamp and the tunnel. replace and reverse instructions. it's part # 306-0095-01
May 14, 2008 | InFocus ScreenPlay 4805 Multimedia...
Sharp XR-32X Projector Logo
89 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
