Question about Sewing Machines
Won't pick up bobbin thread
My daughters prolectrix 8 stitch sewing machine won't pick up the bobbin thread. she has used it before and it was ok, unfortunately she has also left the instruction manual at her student accomodation.
    Problem Solver:
  • 5 Answers
Does she have the right needle in? If the needle is to short it won't pick up the thread. If that is not the issue than it could be timing
Posted on Jul 29, 2009
Hello, I recently purchased a brother lx3817 sewing machine and it works but doesn’t stitch, what could be the problem
hi Desiree.
this is all i could find out.
There could be several things that could cause the machine not to pick up the bobbin thread.
  • The upper thread could be tangled.
    Remove the thread completely from the machine.
    The correct size spool cap should be used for the size of the thread spool.
    Re-thread the machine according to the directions in the manual.
One Point Advice Place a spool of thread on a spool pin.
One Point Advice Upper threading
  • Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race.
    Remove any loose threads or lint in the shuttle race.
One Point Advice Installing a bobbin into a bobbin case
  • You could be holding the needle thread too tight.
    Hold the thread lightly to keep the end from going down into the shuttle.
  • The needle could be thread incorrectly.
    Thread the needle eye from the front to the back.
  • The needle could be bent or improperly inserted.
    Install a new needle with the flat side of the needle facing the back.
or this link might help you out some more.
Why won the machine pick up the bobbin thread Brother
or this one.
brother lx3817 sewing machine doesnt stitch Google Search
Dec 06, 2017 | Brother Sewing Machines
My Bernette 715 isn't picking up the bobbin thread and is getting jammed. Any ideas what's wrong?
First thing to always try: Install a brand new needle. A dull, worn, or bent needle will cause great frustration. It is also the least expensive resolution to most problems.
Second: Remove all the threads. RAISE the presser foot. Rethread from the beginning making sure it is threaded correctly.
Pull up the bobbin thread before beginning to stitch and hold the thread tails in the left hand while slowly taking the first few stitches:
How and Why to Bring up the Bobbin Thread
If still having issues with not pulling up the bobbin thread, the needle/hook may be out of time.
Sewing machine won pick up bobbin thread hook timing fix
Feb 06, 2016 | Sewing Machines
John Lewis mini sewing machine
This was really helpful for me fixing my daughter a John Lewis (janome) mini sewing machine, and now can get the bobbin thread up again, however, when you sew, the thread is not staying in stitches, just coming off the material completely. I tried forcing the gears on one more time but then it didn't pick up the bobbin thread again so went back to the other gear position. Any ideas of what to try and get it stitching again? Thanks
Apr 02, 2013 | Janome Mini Compact
Singer Golden Touch & Sew Model 750 sewing machine. Machine won't straight stitch, won't pick up the bobbin thread.
Try a new needle first failing that you may need to retime the machine, you can email me for an attachment of instructions kendourof@yahoo.com
Aug 27, 2011 | Sewing Machines
Prolectrix 8 stitch sewing machine top thread keeps getting caught round bobbin housing and jamming everytime i try to use it
Sounds like the take-up lever is not threaded.
Remove the thread from the machine, turn the handwheel until the take-up lever is at its highest position, raise the presser foot and rethread the machine. Set the upper tension dial to 5 and retry.
Aug 18, 2009 | Sewing Machines
Bobbin unravelling on prolectrix 8 stitch sewing machine
did you put the bobbin thread in the tensioner? that would be the cut in the side of the bobbin case to pull the thread under the tensioner. if not it will cause problems. but if the top thread is looking good then the top thread is the problem, thread the machine with the presser foot up to let the thread into the tensioner, if it looks good on the top and not the bottom it is the upper thread if it looks good on the bottom and not the top it is the lower thread
Jul 29, 2009 | Sewing Machines
Needle not picking up bobbin thread on Prolectrix 8 stitch
my machine is not picking the thread from down bobbin thread ,i am fallowing the all instruction for threading.
Jul 21, 2009 | Sewing Machines
Problems with prolectrix sewin machine
you have to make sure the bobbin thread is positioned right in the middle. When the needle comes down (into the bobbin compartment), you can peer into the bobbin compartment and see a loop of thread (coming out of the needle). You want to catch that bobbin (thread) in the loop of thread (that runs from the needle).
Feb 15, 2009 | Sewing Machines
Sewing Machines Logo
584 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
