Unless the manufacturer offers a rebuild kit, a rebuilt sub will never be precisely the same as it was originally. The best option is to send them in for repair. If they are inexpensive, it may be less expensive to purchase new subs.
If you blew them once, it's likely that you'll blow them again so the replacements should be rated for higher power handling.
how do I hook up one sub to my p3001 amp? It has an A and B speaker intputs. Do I bridge it or what?...
(More)
how do I hook up one sub to my p3001 amp? It has an A and B speaker intputs. Do I bridge it or what? Thanks
Peavey PV 8.5C DDT is activated on channel A even al low volume, channel B works fine. All 8 power...
(More)
Peavey PV 8.5C DDT is activated on channel A even al low volume, channel B works fine. All 8 power transistors on both channels were found OK. Driver transistors and 15V zener diodes are all OK as well. Supply voltage on both channels are all OK. Triac and switching transistors on the PA board were found OK. Any help is highly appreciated. Many thanks. Leo
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
