Question about Whirlpool Dryers
Dryer runs for about 5 minutes and shuts off.
The dryer runs for about 5 minutes and shuts off. Very hot to touch. I disassembled the dryer and vacuumed out all of the lint yet problem is still there.
  • 86 Answers
You may have a faulty motor winding or run capacitor.If the motor wind is shorted it will get hot and the thermal cutout goes open circuit (inside motor)and it starts again when cool.Also check that the air flow is OK eg Some models have a separate fan belt.Hope this helps.Cheers.
Posted on Jul 28, 2009
Why does my Whirlpool electric dryer - model SEDS800JQ0, shut off after 2 minutes?
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Aug 09, 2014 | Whirlpool Dryers
G e electric dryer model #GTDP300EM1WS shuts off after 5 or 10 minutes
I would guess your high limit is tripping. Does it seem excessively hot when it shuts down?
Apr 12, 2013 | Dryers
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Our 4 cycle whirlpool dryer runs for 5 -10 minutes gets hot and shuts off.
check to see if the dryer vent is clogged up - When a dryer gets to hot it will shut off to prevent catching fire!!! If the vent is clogged it forces the heat from the dryer to stay in and that causes the dryer to over heat!!!
Jun 25, 2011 | Dryers
DRYER GETTING HOT---CLOTHES TOO HOT TO HANDLE----BLEW THE THERMAL FUSE---REPLACED THAT AND THE CYCLING THERMOSTAT------WENT THREW THE CYCLE---THEN THE WIFE ADDED SOME MORE TIME AND IT SHUT DOWN IN ABOUT 5...
Sounds like your vent is stopped up . Pull the dryer out from the wall and disconnect the 4" vent. Look into it and see if it is stopped up with lint. If so clean it out good. Also, make sure the hose isn't pinched.
May 14, 2011 | Dryers
Dryer runs for about 5 minutes then shuts off the clothes are hot
Your vent may be obstructed causing the dryer to trip, once it cools down it will reset itself. The way to see if thats the problem is to disconnect the vent and run the machine, if it doesn't shut off, you will need to clear the vent.
May 13, 2011 | Kenmore Elite HE4 Electric Dryer
Heating element is getting too hot and shutting down dryer
Disassemble the dryer again and check the blower wheel on the motor shaft. It may be slipping.
Also,remove the rear exhaust vent and run a load. The blockage could be in the outside exhaust.
May 25, 2010 | Maytag PYE2300AY Electric Dryer
Dryer smells hot and back panel near heating
your duct is clogged or the limit snapstat is not working. turn dryer on and go outside to the duct vent , their should be a minimum temp of 10 degrees, and a maximum 15 degrees outside. also sometimes just cleaning the lint from inside the dryer, can cause this smell for no more than 5 minutes. thanks karl
Dec 15, 2009 | GE DBXR453EV Dryer
Dryer shuts off after about 5-10 minutes of running. The top of the dryer is hot.
Howdy: There is a thermostat inside the unit in the back. If this has lint clinging to it, it will shut off unit. Also the firing ignitor has two soleniods
that stick and turns off unit too early. But with the top of dryer hot I would say the heat always stays on and the thermostat shuts off ignitor. The firing should be a pulse type heat, not a constant heat. Good luck - Doug
Dec 08, 2009 | Kenmore Dryers
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Dryers Logo
119 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
