Question about Cuisinart Thermal DGB-600 Grinder
Program light is blinking and will not turn off
I went to make coffee and I cannot get the prgram light off...it is blinking and is overriding all the other buttons. how do I turn it off?
  • 5 Answers
Mak sure all pats are back together, grinder unti top to grinder unit, closed basket etc. If the beepin will not stop after that unplug unit for about 5 minutes then plug back in , once again making sure everything is closed. The beeping is to warn you that a part is not there and a leak is posible if tht the case. Hope that helps, Steve
Posted on Aug 02, 2009
How can i find the anti theft reset button on 2006 taurus
this is for a 2003, might work.
Press the unlock button on your vehicle's key fob to deactivate the alarm. If you've misplaced your remote for the car, use the PATS programmed key to unlock the driver's side door. Then, put the key in the ignition and turn the key to the "on" position. The vehicle's battery should be on, but the engine shouldn't be running.
Locate the override button on the alarm box, beneath the driver's side of the dashboard. Press the button and hold it in until the alarm beeps one time. The LED light for the alarm should stop blinking, indicating the anti-theft system is disabled.
To reset the vehicle's alarm, put the PATS programmed key in the ignition and turn the key to the "on" position. Press the override button. When the alarm resets, it chirps two times and the LED light begins blinking.
Jun 13, 2016 | 2006 Ford Taurus
Prime message and blue blinking light. It has plenty of water, I don't understand why it isn't working. Please help, Jenna
what exactly is it doing? need more information than prime message and blinking light.? please give me more info. lkadera@gmail.com.
Aug 29, 2011 | Keurig Platinum B70 Coffee Maker
How do I program my DeLonghi DCM 485?
Hi and welcome to FixYa, I am Kelly
First you must set the clock. Page 6 of this pdf manual:
http://www.smallappliance.com/images/SmallAppliance/English/products/standard/DCM485.pdf
Then prgram per instructions at the bottom of page 6 and the top of page 7 of the same manual. I note step 2 is missing from the manual.....
3. Press the CLOCK button until the desired brewing time is displayed
(See "How to Set the Clock" section of the manual).
4. Press the ON/OFF button to confirm the automatic time selected.
NOTE: The display panel and the on/off indicator light will flash.
5. Press the PROGRAM button to return to the current time of day (the
ON/OFF button will continue to flash.) The brewing cycle will begin
once the set time is reached and the ON/OFF button stops flashing.
6. If you want to check the automatic time selected, press the
PROGRAM button.
7. To override the automatic brew function, press the ON/OFF button
and the coffee maker will start immediately. Press the ON/OFF
button again to switch the coffee maker off.
Thanks for choosing FixYa,
Kelly
May 21, 2011 | DeLonghi DCM485 Coffee Maker
I can not get out of descaling mode. I turn it of, unplug it, went into programing mode. Is there a way to reset it? Thanks
If you are talking about the descale light, you must let the machine quit on its own. The pump has to stop on its own. Any interruption (you stopping the machine) will keep it in the descale mode. Once it stops on its own, the lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle (putting water in the tank and closing and then reopening the steam knob)until all the red lights go away and you only have a green blinking light. Now your finished descaling a compact without a digital display.
Jul 17, 2010 | Gaggia Syncrony Compact Coffee...
The program light won't stop blinking
Same here. I'm dead in the water. This started happening a few weeks ago and with patience and luck and different combos of buttons I'd get it to stop and I was able to brew. Today it just stopped completely. The program light either blinks constantly or stays lit constantly, but I cannot brew coffee. I see lots of people online with this problem, but have yet to see a solution.
Dec 08, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Braun Coffeemaker Programming
to prgram the automatic operation, press the automatic buton until the green pilot light begins to flash. The time "12:00" or the previously programmed time appears on the display. When the green pilot light begins to flash, release the button and press the hour and minute buttons until the correct shows; ensure the hours are am or pm. After programming is completed, the green pilot light will go off after 5 seconds.
Dec 08, 2008 | Braun FlavorSelect KF 180 Coffee Maker
Cleaning light will not quit blinking after cleaning
The same thing happened to our Mr. Coffee this week! I followed the instructions about running vinegar through, then rinsing several times with water. However, the light would not stop blinking. We did by-pass the light by setting the timer for delayed brewing and it worked. However, that blinking light came on again. Then, my husband tired the vinegar wash again but instead of doing it one time, he ran the same vinegar through 6 times until the light went out! Then he proceeded with the water rinse. Our Mr. Coffee is working again!
Nov 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Programable Timer
After you follow the directions in the manual, you have to press the Program button one more time so that it lights up - THEN it will make coffee at the set time.
Aug 22, 2008 | Cuisinart Thermal DGB-600 Grinder
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
My GE television wont program
i lost the origanal remote to my televison and i went and bought a new one but the tv wont let me prgram it to get more channels is there a way i can get more channels or is there no way to get all the channels
May 04, 2007 | GE 25GT240 25" TV
Cuisinart Thermal DGB-600 Grinder Logo
149 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
