Question about AT&T Cell Phones
My blackberry will not start up. I've tried two
My blackberry will not start up. I've tried two batteries and on power up the only thing that shows is a picture of a battery with a red line through it. The unit will not go past this screen. I have removed and reinserted both the sims card and battery.
I would have never believed it but after reading others posting this same problem I tried thier suggestion. Since the phone was a brick anyway, the idea was to drop the phone from a height of 4 foot and then turn it on. After several drops from shoulder height, I finaly tossed it at the ceiling and let it fall to the floor, distance approximately 8 feet. After three attempts the phone booted right up and has worked great ever since. The phone is a Blackberry model 8700c.
Posted on Jul 29, 2009
Blackberry pearl 8220 reload softwares 513
If your tried to WIPE the phone and you've still got error?you need to update your phone firmware,to do this,just follow this link and it will lead to a step by step updating procedure . FOLLOW ME
Be sure,
* Battery is fully charge.
* usb cable is working fine.
If you can't do this thing,just bring the phone to a service center for assurance.
Aug 03, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
My toshiba satellite a205 will not start. the battery light flashes 6 times and stops, no other lights come on. I've tried removing the battery and power cord and holding down the power button for...
If it does the same thing w/ the battery removed and just on AC, it's a power regulator problem on the motherboard. If it works with the battery out, the battery is dead and you need a new one.
Jun 30, 2011 | Toshiba Satellite A205-S4617 Notebook
My blackberry is showing reload software 552
Try the following steps to reload the software for your blackberry. You will need BB desktop manager (which you download from blackberry.com. Good Luck
  1. Verify that the BlackBerry® Desktop Manager and the current BlackBerry Device Software (for your BlackBerry smartphone) is installed on the computer.
  2. Remove the battery from the BlackBerry smartphone. Do not re-insert the battery.
  3. Open the BlackBerry Desktop Manager on the computer.
  4. Connect the BlackBerry smartphone to the computer using a USB cable.
  5. On the BlackBerry Desktop Manager main screen, click Application Loader.
  6. In the Update Software area of the Application Loader, click Start.
  7. Click Options. This allows you to add or remove applications from the BlackBerry smartphone.
  8. Select the applications that you want to install.
  9. Click Next.
  10. Click Next.
  11. Click Finish.
  12. When the application load process starts, insert the battery into the BlackBerry smartphone.
Apr 12, 2011 | RIM BlackBerry Curve 8520 Smartphone
I,ve switched on my blackberry curve this morning and its telling me to reload software 552 can u help
Take it to your carrier's local store. They will provide you with much more personalized help.
Mar 24, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry charge symbol appears but does not charge battery
are you using the charger that came with the BlackBerry?  cause sometimes that can make a difference.
otherwise you might just need to get a new charger.
and usually the wall chargers work the best.
i had a BlackBerry Pearl 8100 and the same thing happened to mine.
Aug 20, 2009 | RIM Blackberry Curve 8300
1994 gw Interstate - turn key on - no lights neutral or oil press
It sounds like there may be an electrical leak, If the voltage goes too low, the computer either shuts down or it can go stupid where certain things won`t operate. Try turning everything off, disconnect the positive lead from the battery and connect an ammeter between the positive terminal of the battery and the positive connector that goes to the bike. There should be very little drain from the battery, (I presume it`s got a clock and maybe a radio with presets that require power). I would say if there is more than say 10 - 50mA showing on the meter, you`ve got a leak. I`ve just been explaining about one of these bikes where it was the rectifiers that were leaking. I`m only guessing so I hope this helps. Ian
Jul 15, 2009 | 1990 Honda GL 1500 SE Gold Wing
Solution for 7290 blackerry frezzes up how do i reset?
Try resetting the phone by powering off, removing the battery leaving for 30 seconds reinserting the battery and powering on.
If that doesn't work hold down ALT+RIGHT SHIFT(CAP)+DELETE keys simultaneously unti you get a blank screen.
May 11, 2009 | RIM BlackBerry 7290
My Blackberry Curve 8310 will not power up.....
That usually is a sign of a dry cell in the battery.  You might be able to boot by plugging in the wall charger to it with the bad battery.
Mar 25, 2009 | RIM BlackBerry Curve 8310 Smartphone
Fter power switch put on it show blank screen and no sound only battery and power indicator is on but hard drive indicator is off. does that is a cause or some hardware problem?
it's possibly a hardware problem but you should make sure it isn't a software problem by putting in your system restore cd and restoring the DLL that you deleted, it could be an important system file. If it is a hardware problem, the first thing to try is taking out your memory and sticking it back in place, make sure it's clean and put it in there tight.
Jun 25, 2007 | Sony VAIO VGN-SZ460N/C Notebook
Cell Phones Logo
399 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
