Back to:
Tags:
Car Amplifiers
Generic problem for all Car Amplifiers
Amps
posted by mayboy on Nov 22, 2007
how can i get more wattage out of a lighting audio 150 watt lighting bolt amp other than brideging it over
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Nov 22, 2007
Not Rated (0)
nosamsguy
Rank:Wiz Wiz
Rating: 88%, 41 votes
Your amp is at risk of overheating and blowing if the specs are exceeded. Run bridged mode and get 2nd amp.
To get the most reliable work out of your amp, the speaker loads need to be the lowest impedance recommended. Make sure the 12v supply remains stable, good ground, larger wire (8AWG or better)will reduce voltage drop and a large cap(100,000uF) across 12v line will help with large current pulses. Keep the amp cool. No small air tight enclosures. Fans??
Tech stuff
E Squared/R=P. E(RMS speaker voltage), R(speaker impedance), P(watts). Only way to get more watts is to increase E or reduce R.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on amps:
I don't want to Accept this solution
Can you Help with these Car Amplifiers problems?
US Acoustics USX-2050 Car Audio Amplifier
could you pls help me
MA Audio Hard Kore HK-898 Car Audio...
Technics amp su-vx800 goes in to protection mode after...
Car Amplifiers
my anp works fine. but when i bridge it. it seems to melt...
Alpine MRA-F350 Car Audio Amplifier
I have just installed an Alpine IVA-D106 to an Alpine...
Crossfire VR4000d Car Audio Amplifier
i need guides of the crossfire vr 4000 d for more...
Loading problems.
Repair Service
Find Car Amplifier Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
