Question about Sewing Machines
Slant-O-Matic 401. Bobbin tension to loose. Have tried turning screw, just won't fix this time.
  • Sewing Machines Master
  • 12,731 Answers
It could be that the bobbin case is old and worn (normal with wear-n-tear). You should be able to find a replacement that will work. Check at the local sewing repair shop.
Posted on Sep 04, 2017
SOURCE:
  • 84 Answers
SOURCE: Janome Memor Craft 10001 bobbin tension
There is an adjustment on the side of the black bobbin case.
Remove the needle plate, to gain access to the case. Lift it out, noting how it is positioned! On the side of it , there are two screws, one is the adjustment screw - its the one that sits out more. To increase tension, turn it clockwise 1/8th of a turn, reassemble and test sew. (make sure the top thread tension is back to where it should be). Repeat if required. DO NOT adjust too much at a time!
Good luck
Posted on Oct 22, 2007
bargainbox
  • 1388 Answers
SOURCE: bobbin tension
This is an issue of your upper thread tension, so take a look at this generic tension solution
If you are in a pickle with your bobbin case, check top tension and bobbin case are free of lint, reset the top tension to 4, and adjust the bobbin tension to suit......some more detail on how to do that, is here
Bargain Box
Posted on Jan 30, 2008
  • 323 Answers
SOURCE: Tension
I'm assuming the thread is looping on the bottom. If this is not the case, ignore the rest of this.
Perform a tension test. Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
sewman7
Posted on Aug 02, 2008
  • 97 Answers
SOURCE: thread or bobbin tension
Thread tension. Beware of adjusting the bobbin screw. Pfaffs maintain their tensions just fine without adjusting the bobbin tension, unless you're using some crazy thick or fine thread. If you must change your bobbin tension, you would be well-advised to buy an extra bobbin case, because re-calibrating your tensions after changing them can be less than fun.
Increase your top tension, and your looping should cease. I normally keep my tension around 4.5. Also make sure you're using a good quality thread, and that there's nothing in the upper tension assemblies. Sometimes a tiny piece of debris can keep the top tension from applying enough tension, so turning the machine off and blowing some canned air in there can help as well.
Good luck,
-R
Posted on Mar 11, 2009
  • 371 Answers
SOURCE: The bobbin thread on my Viking Designer 1 is too tight
In most cases, this is caused by loose threads and fluff being in the upper tension unit rather than a problem with the bobbin. There is a screw on the bobbin case that losens and tightens the resistence. However, it can easily come out and then you have a mess.
Try this to check the bobbin thread tension -
Take the bobbin case holder out of the machine. Use a bobbin that is about half full and use standard 50 wt sewing thread.
Take your needle plate (the metal plate over the feed dogs that has markings showing stitch width under the presser foot).
Thread the bobbin thread in the bobbin case, holding the case so that the thread is through the tension spring as though it is in the machine, tied the end of the tread to the needle plate and have it hang below the the bobbin case.
If the needle plate immediately drops to the floor, unwinding the bobbin, the bobbin tension is too loose. If you jiggle the bobbin case slightly up and down and the needle plate moves slightly down, it is just right. If it does not move at all it is too tight. The resistence should be 14g which is the weight of the needle plate.
The upper tension unit, look straight down from the tension unit and you should see some metal disks which the upper thread rides through when threaded. Take your small cleaning brush and brush out any loose threads/fluff there. Look down the left side of the tension unit to make sure there is none hiding.
When you tighten the upper tension unit by pushing the tension buttons on the screen, do you hear the tension disks tightening? If not, it may be the pc board or the tension unit itself that will have to be replaced.
Otherwise, you might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck
Posted on Feb 13, 2010
My Singer Slant-o-Matic 500a sewing machine will not wind a bobbin. The winding pin barely started to turn, then no motion. Also, the wheel doesn't seem to tighten.
Your machine is an older mechanical machine, so have you cleaned and oiled it recently? Usually, older machines' oil will gunk up over time and stop things from moving like they should. Use only Fresh, good quality sewing machine oil. Do NOT oil belts, cams, rubber, or plastic parts. Slowly rotate the handwheel and place a couple drops of oil every place where metal rubs metal. To speed up the process, direct hot air from a handheld hairdryer into the internal metal parts.
singer 500a bobbin winding
How to Inspect Rubber Bobbin Winder Wheel Singer 500 503 Sewing Machine
BrianSews Singer Slant Matic 500a the Rocketeer
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0ahUKEwjqkcWf7KrMAhVB4GMKHVwoA-MQFggvMAQ&url=http%3A%2F%2Fwww.singerco.com%2Fuploads%2Fdownload%2F1308_500.pdf&usg=AFQjCNFEBkPQttXzueRCWGluOe-YBmF5Wg&cad=rja
Apr 23, 2016 | Singer Sewing Machines
When i sew a test piece of fabric on my sewing machine to check the stitching, the top thread seems fine but the bottom thread is loose and adjusting the tension doesn't seem to help
there are two thread tensioners on a machine
the first one is on the front of the machine for the top thread
the second is the small screw that holds the small flat spring under which you pull the thread after you put the bobbin in the holder
as you put the bobbin in the holder you have to pull the thread around the side until it slips into a small slot then under a retainer spring
that spring is adjustable by that small screw
the amount of tension added or released by that screw is minute so as little as 1/8 turn has a big bearing on the amount of tension of the bobbin thread so turn it just a small bit at a time until the thread tension is correct
Oct 14, 2015 | Sewing Machines
How do I fix a bobbin tnesion problem>
Bobbin tension is one of the biggest problems most sewing machine operators have. Check information sent for assistance on this.
Jul 23, 2015 | Sewing Machines
Loose bobbin tension
the bobbin tension is set by that small spring plate that you pull the thread under after you put the bobbin back in the carrier / holder
a very small turn of that screw makes a big difference ob the tension unlike the needle thread tension
mostly the problem ( you never bothered to mention the symptom ) is bird nesting under the fabric which is the needle thread tension not tight enough
Jul 06, 2017 | Brother SE-270D Computerized Sewing...
Singer 401
Hi Sara
If you don't have the manual for your Singer 401 you can find it online for FREE. Lots of people try to sell these but they are usually available somewhere online for no charge. Here is the link to the one I found:
http://www.ismacs.net/singer_sewing_machine_company/manuals/singer-401-slant-o-matic-sewing-machine.pdf
There is a section on adjusting tension for the needle by turning the tension knob. Sometimes you have to try a test run on a scrap of fabric. If it is too loose then turn the tension to a higher number, if too tight turn to a lower number. Probably start in the middle around 4 or 5 The bobbin tension is adjusted with a screw. Then manual has some illustrations. Hope this helps.
Lola
May 28, 2013 | Sewing Machines
Won't sew stitch patterns, thread gobs up on underside fabric
it is called bird nesting and indicates that the needle thread is not tight enough
Dec 14, 2017 | Singer Sewing Machines
I need to know how to adjust the bobbin tension on my euro-prox sewing machine.
There is a tiny screw on the side of the bobbin case.
Mark the **** (in the screw head) position on the bobbin case with tiny dab of nail polish so you will know where the original setting was.
Left/loose and right/tight.
If you are adjusting because the bottom stitching is loose/loopy, first try threading the machine with the presser foot up to see if this solves the problem.
May 01, 2010 | Euro-Pro Shark 60 - 384
Loose stitch
try to tight firest screw on bobbin or remove it and clean spring from dust and fix it agine
Aug 15, 2009 | Janome D'cor Excel Pro 5124 Mechanical...
Sewing Machines Logo
124 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
