Question about Dell Optiplex GX270
CPU CASING CAN I CHANGE MY DESKTOP CPU CASING TO DESKTOP TOWER ?
    Master:
  • 404 Answers
Yes you can, but its not easy and a risk of scratching your motherboard can cause faults or even kill it. it is not necessary and wont make it go faster. a simple dust cleaning should do the job.
Posted on Jul 28, 2009
When i turn On my PC this thing shows in the monitor. <300 XT BIOS P/N 113-A33437-102
Open the case, loosen the 2 screws holding the black plastic casingon the cooling tower over the CPU. Carefully remove, or tilt back to reveal cooling tower radiator and coil.
If there is a layer of dust built up (like there was on mine); carefully vacuum clean the radiator, cooling tower unit, fan and all other surrounding areas. Clean any residue from tower-to-CPU contact area.
Vacuum entire PC inside and out. Remove, reseat, vacuum video card. Reseat storage drive cables reseat the memory sticks, close it up and plug it back in start computer.
Jun 05, 2014 | Dell Dimension 5100 (D51L1) PC Desktop
Fan stops working and overheats and shuts down
Hello, its seems the fan on your card is faulty, because of this it your card overheats and then has to shut down to prevent damage to your computer. You should get it replaced.
Thanks for sharing
Jul 05, 2011 | ATI RADEON X1650 Graphic Card
Unable to power on computer
When you here this signal sound beeping this is an RAM memory error. Try to open your CPU casing and remove the RAM, clean the RAM with rubber eraser.
After that insert the RAM and try to turn on the unit. Once you can hear again the loud sound beeping the RAM are bad or faulty already. So you need to replace the RAM.
Jul 25, 2010 | HP Compaq d530 SFF PC Desktop
Dell 4700 desktop, will not boot up. Light remains
A solid Amber power LED is an indication of a motherboard problem. Remove any external connections and see if LED indications change. If no change, remove all PCI expansion cards, try again. If still no go, disconnect all drives, try again. If still no change, ensure the CPU heatsink is firmly attached (If loose you need to replace the retention module) If nothing loose and no changes from other steps, replace motherboard
Mar 11, 2010 | Dell Dimension 4600C PC Desktop
Acer Aspire M1640 PC monitor 'no signal', tower non-responsive.
i found the same problem (can't load BioS) but we are not alone as you can see on web about M1640 and M1641 it's very popular defect
I made various test:
cpu (pentiun e2180) pass the test mounted on another PC.
I removed the two ram and replace with other ,result nothing (Pc power on but can't load the BIoS).
Some of this Acer model have this motherboard crash
look also here
http://www.tomshw.it/forum/schede-madre-e-ram/129267-scheda-madre-non-da-segnali-di-vita-microstar-n1996.html
http://www.tomshardware.co.uk/forum/271665-12-motherboard-problems-m1640
http://www.fixya.com/search/p954810-acer_aspire_m1640_refurbished_intel_desk/acer_aspire_m1640_fast_ddr2
http://www.tomshardware.co.uk/forum/270660-12-acer-motherboard-sak09-replacement
Change the MotheBoard
Mar 10, 2010 | Acer Aspire M1640 Refurbished Intel...
Tower wont stay running
Are there any beeps?
Could be the power supply going, motherboard, memory or CPU.
Check that all of the cards are seated correctly and tight.
Feb 06, 2009 | HP Pavilion a420n PC Desktop
Removing outer casing of tower ?
remove outer case of ur cpu white cable will there inside place ur dvd in the top of the cpu connecvt the cables
Jan 30, 2009 | Dell Dimension 1100 PC Desktop
HP D330 desktop system sound problem
Did you check the audio settings in control panel. you need to select the appropriate hardware from the drop down list. See if it works.
Jan 26, 2009 | HP D330 PC Desktop
Upgrade cpu on pavilion 6630
i am suggesting you the solution keeping in mind that there is no display is on the monitor.
The max ram that HP Pavilion 6630 PC Desktop can support is 256 mb pc 100 or pc 133mhz.
check if you have installed that amount of ram, if thats correct then check if any continues beep sound is coming out of CPU.
if there is beep try to change the ram slot.the more possibilty i either the new ram is faulty or incompatibel.
try to install the old ram see if it works. if still no display.
install old cpu and heat sink.see what happen ..
then let me know the result.
bye & take care..
Jan 02, 2009 | HP Pavilion 6630 PC Desktop
Dell Optiplex GX270  Logo
49 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
