Question about A D S 346im Coaxial Car Speaker
Motorcyle installation I have a 08 Harleydavidson roadglide and I want to run a component system with 4 6x9s two in each bag for subs two more 6x9s in the leg warmers (farrings) for mids and in the dash 51/4s along with the tweeters do you think I can get premium sounds with the right equipment and what do you suggest for equipment
After running a Shop in Philadelphia for several years I have to Say, Cerfer39 is dead on here. besides the inherent road noise that interferes with the sound quality there is something inherently difficult about putting a sound system on a Harley. The engine vibration degrades the sound from any speaker that is not isolated. Getting that kind of isolation on a bike is not going to be easy. Keeping it is going to be even more difficult. the type of vibration created here is known to rip 16 gauge steel battery straps. Not much on the market today is going to stand up to isolation needs and still not tear apart. Besides the helmet systems are incredible at delivering quality sound, and communication from bike to bike... added Luxury!!!
Posted on Nov 24, 2007
  • 709 Answers
Hi 1 2fade,
The market in Motorcycles, especially Harley Davidson pushes for helmet speakers. You cannot possibly get good sound when riding with externally mounted speakers. Only when sitting at an event will give you decent sounds. You probably already know this. I suggest pioneer Marine grade equipment, and a premium brand of Marine grade. I also suggest you gett a Helmet set so you can enjoy great music while riding if you dont already have it.
Installing a sub into 08 dodge caliber factory radio
Check for female RCA line signal output.
I don't think factory radio will has RCA output.
It does not hurt to check.
Jan 18, 2014 | Cars & Trucks
No bass from Bose AM 15 Sub
Sub will only work in surround mode, not stereo mode. Also source must have sub component (5.1, 7.1, 9.1 etc) If your system was transmitting sub signal before, be sure you have chosen a mode which includes a sub signal.
Nov 11, 2013 | Denon Audio Players & Recorders
Loucd clicking noise no oil pressure 08 roadglide
Hi G.R., and the usual suspects are:
1. Oil tank/pan underfilled.
2. Faualty low oil pressure switch.
3. Oil pump o-rings damaged or missing.
4. Oil pressure relief valve stuck in the open position.
5. Ball missing from cam support plate.
Good luck and have nice day.
Jul 26, 2012 | Harley Davidson FLTR Road Glide...
I changed my window from window vista business to window xp , now i have window xp. but after installed it i lost the sound of my laptop compaq presario c700. i lost audio and sound device,...
you just go to control panel add/remove programm then
Click the "Add/Remove Windows Components" button on the left side of the window to display a list of available components.
Highlight any available component you want to install like sound. If the "Details" button is displayed, click to view sub-components. Check the box next to the "Sub-Components" or "Components to Add" options.
Click the "Next" button to complete the configuration wizard and the "Finish" button to close the Windows Components Wizard
Oct 22, 2010 | Computers & Internet
How do you replace a ignigtion lock cylinder on a 1998 dodge
NOTE: The Supplemental Inflatable Restraint (SIR) system must be disarmed before removing any components in the area of the air bag system. Failure to do so may cause accidental deployment of the air bag, resulting in unnecessary SIR system repairs and/or personal injury.
Disconnect and isolate the negative battery cable from the battery.
Allow the SIR system capacitor to discharge for at least 2 minutes, before performing any removal procedures. The air bag system is now disabled.
Remove the key cylinder (ignition lock).
Using a No. 10 Torx® tamper proof bit, remove the ignition switch mounting screw. Depress the ignition switch retaining tab and carefully pry the ignition switch from the steering column.
Disconnect the electrical connectors from the ignition switch and remove the switch from the vehicle.
Be sure the ignition switch is in the RUN position and the actuator shaft in the ignition lock housing is in the RUN position.
Reconnect the electrical connectors to the ignition switch.
Carefully install the ignition switch, making sure the ignition switch snaps over the retaining tabs.
Install and tighten the ignition switch mounting screw.
Install the key cylinder (ignition lock). Complete the installation by reversing the removal procedures.
Reconnect the negative battery cable.
Check switch operation.
Good Luck and hope this helps
May 01, 2009 | 1998 Dodge Caravan
Srs warning light is staying on
Supplemental restraint system warnig light should be checked by dealer to make sure that it is not just a reset problem.Ask the dealer if disconnecting the battery could have caused this. People who install stereos usually don't have factory training on air bags When the srs light is on the air bag system is non functioning. Please have it checked.
Apr 28, 2009 | 2008 Mitsubishi Eclipse
Airbag deployed
SECTION 501-20B: Occupant Restraints — Passive — Supplemental Air Bag System 2000 Villager Workshop Manual REMOVAL AND INSTALLATION Module —Driver Air Bag Removal
syv~us~en~file=ani_caut.gif~gen~ref.gif WARNING: The backup power supply energy must be depleted before any air bag component service is performed. To deplete the backup power supply energy, disconnect the battery ground cable and wait three minutes.
NOTE: Repair is made by installing a new part only. If the new part does not correct the condition, install the original part and perform the diagnostic procedure again. If the vehicle was in a frontal collision and the air bag did not deploy, the air bag may not have been needed. Complete a diagnosis of the air bag system before installing a new driver side air bag module (043B13). Refer to Diagnosis and Testing in this section.
  1. Disconnect the battery ground cable (14301). For additional information, refer to Section 414-01 .
  1. Remove the two driver air bag module retaining bolt access covers (one shown).
  1. Remove the steering wheel bottom cover to access the driver air bag module electrical connector.
  1. Disconnect the driver air bag module electrical connector.
  1. syv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: After removing, discard the driver side air bag module bolts and install new driver air bag module bolts during installation.
    Remove the two driver air bag module retaining bolts (one shown) and discard.
  1. Remove the driver air bag module.
    1. Separate the driver air bag module from the steering wheel and disconnect the horn pad switch.
Apr 16, 2009 | 2000 Nissan Quest
I am trying to install a amp and sub in my 08 gmc
dont need a diagram,, most amps have a speaker level input...dont mix this up with line level....connect your wires from back of factory speakers to speaker level input on amp...then if your amp has a low pass switch select lowpass setting now you have punch
Mar 29, 2009 | 2008 GMC Sierra 1500
Visual studio instalation problem
just take a look to this site:
you will get your answer there easily.enjoy it!
Feb 23, 2009 | Microsoft Visual Studio® 2005 Professional...
A D S 346im Coaxial Car Speaker Logo
70 people viewed this question
Top A D S Car Audio & Video Experts
Mark Skinner
Tom Chichester
Are you an A D S Car Audio and Video Expert? Answer questions, earn points and help others
