Question about Onkyo TX-NR801 Receiver
TIVO I can't get my TIVO remote to recognize the 7.1 receiver.  ANyone know the code?  I tried the folks at TIVo and they were not help so far.
    New Friend:
  • 59 Answers
Without model #as for both units + serial #s I can't help you . these are crucial to getting info for this.
Posted on Dec 30, 2007
0 characters
3 Points
HDMI no longer working as pass through for Comcast and Tivo
sounds like your digital board is going bad. Is the unit still under warranty?
Jul 29, 2013 | Marantz Audio & Video Receivers
No sound on TiVO. Tried the mute button. Sound works on TV mode only
Could you give more info on the problem and what all you have tried
Jul 12, 2008 | Audio & Video Receivers
Denon avr 3805 2 zone configuration, I added optical sound from TIVO and now zone 2 is not working. I did the test of the speakers and they all work. I have configured the main for 5 channel stereo.
Zone 2 needs an analog input to work, if you pulled the analog from tivo, put it back on. Digital will not pass on zone 2. If your analog is still connected as well, go into your receivers settings for audio and select "auto" not "digital" Check the settings on tivo as well. make sure it's audio output is set to "auto" if available. If it's not, it's default is "auto" and will output simeltaneously on all outputs. Hope this helps. If you need more help, post a comment and I will help some more.
Jul 05, 2009 | Denon AVR 3808Ci Receiver
Dolby output is Pro Logic II, even though source is Dolby Digital
I know nothing about tivo but dvd player might need to be on bitstream to pick it up.I have to change mine when listening to music. hope this might help.
Mar 26, 2009 | Onkyo TX-SR304 Receiver
Composite a/v and s-video picure look like hell.
I want my computer photo to see it on cd/dvd players
Jan 12, 2009 | Yamaha RX-V663 Receiver
Picture goes blank
Consider re-initializing the machine (Pg. 55 in the manual). The only drawback to this approach is that you'll lose all preset settings.
-Eddie V.
Nov 17, 2007 | Denon AVR-485 Receiver
You might try: 20061
From this link:
Nov 12, 2007 | Audio & Video Receivers
Hdmi audio problem from tivo hd
Your tv is new? if it is then it has a remote link, Panasonic call it Viera link, Sony call it Bravia link. Check your tv if it has that, if it does turn it off.
problem should be solved.
Nov 12, 2007 | Onkyo TX-SR605 Receiver
Video issues w/ Pioneer VSX-816 AV Receiver
Receivers generally cannot or will not convert from one input type to a different output. That's not to say there may not be some high end models around that do that.
I have this receiver and have it setup as follows. Monitor out Component, S-Video, and the Composite video channel (since I have surround sound I have no interest in getting audio to the TV since I keep its speakers off anyways) to their different inputs on the TV. Warning on some TV's if you plug in S-Video you cannot then use composite on that same input channel as it will override and disable the composite. Then you only need to choose the appropriate input on the TV when you switch sources. In my case Tivo is S-Video, DVD is component, and most of my older video games and VCR are composite.
Having a TV that allows you to change the labels for the input channels is helpful with teaching others that may be less adept, or a snazzy remote that you can program to do everything at once.
Aug 30, 2007 | Pioneer VSX-816-K/S Receiver
Onkyo TX-NR801 Receiver Logo
117 people viewed this question
Top Onkyo Audio & Video Receivers Experts
 Mike M
Mike M
D. E. Hev
Are you an Onkyo Audio and Video Receiver Expert? Answer questions, earn points and help others
