Question about Canon imageRUNNER 2000 Copier
System Error E000 and E003
We are receiving System Error E000 and E003
    Scholar:
  • 92 Answers
E002 Error code details Heater temperature error (fails to reachspecific level; inadequate increase)
0000 The temperature of the fixing film is as follows:
1. has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
2. has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
3. has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
Main cause
 The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact, or the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution
 To clear the error, execute the following in service mode: COPIER>FUNCTION>FCLEAR>ERR.
Action
 See the description for E003. E003 Error code details Heater temperature error (abnormal drop; low-temperature detection)
0000 The main thermistor reading is lower than 140°C when paper is moved.
Main cause
 The fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact or has an open circuit; or, the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution
 To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
Action
1. State
 Turn on the power switch, and clear E002/E003. Thereafter, turn off and then on the power switch. Does the fixing heater operate?
 NO: See "The fixing heater fails to operate."
2. Wiring
 Is the wiring from the DC controller PCB to the fixing film unit normal?
 NO: Correct the wiring.
3. Fixing film unit, DC controller PCB
 Try replacing the fixing film unit. Is the problem corrected?
 YES: End.
 NO: Replace the DC controller PCB.
Posted on Sep 06, 2009
    Problem Solver:
  • 19 Answers
In this error you can do the reset ok
Posted on Jul 28, 2009
2 Suggested Answers
myob247
  • 1342 Answers
SOURCE: canon d760 system error e000
You could try the suggestion in this post.
Posted on Jul 03, 2008
How can repair an error of canon 2202 E000-0000 error code?
The E000, E001, E002, E003 and E007 are temperature error codes. Fixing these errors are necessory part of every
photocopier and printer. It is usefull to apply high temp and pressure to melt toner into the fibers. follow these steps
to reset E000, E001, E003 and E007.
Enter into service mode by clicking on key "2" and "8" the SSSW will display
Change bit switch 1 to bit 0
Press OK
http://canonprintersupport.us/
Sep 05, 2016 | Canon Office Equipment & Supplies
System error E000
A E000 coeds means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
The error can be cleared in the service mode.
Contact Canon Consumer Products 800-828-4040
Please let me know if you need any further help
Apr 06, 2008 | Canon imageCLASS D860 All-In-One Laser...
Canon iR 2022 gives a system error E000 and error E003, what could be a problem?
how to clear error code e000 please help me copier ir 2022 show me how to clear
May 19, 2011 | Office Equipment & Supplies
Canon D340 Copier System Error E000
Your printer show Error code E000 suggests the problem history has recognized all of these of the following error codes four moments: Error code E001;Code E002;Error E003. Printer Canon E000 error will be removed in the service mode.
Please try reset factory your canon printer..but if it still show error code E000 again ,you can try with a genuine fuser unit (reseting fuser unit). Good luck
Solution 3: Try this, atempt will clear canon E000 code in Service mode:
1.Press ADDITIONAL FUNCTIONS, #
2.Go to #7 Printer and Press OK
3.Go to #4 Printer Reset and Press OK
4.Yes = ( * )
Sep 09, 2010 | Canon PC-D340 All-In-One Laser Printer
System error E000
Mar 24, 2010 | Canon imageRUNNER 2010F Copier
System error e000
E000
The error history indicates any of the following error codes 4 times: E001, E002, E003.
Which relates to the fuser temp. you need to change the fuser unit.
Sep 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
Cannon image runner 2200 error code E000002-0000, how do I fix it?
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Sep 25, 2009 | Canon imageRUNNER 2200
System Error E000
okay lets shed some light on the E000 error code on the D680, D880, IR1300 family ( including the 1310,1330,1370,1630,1670)
The error code E00 is a memory threshold error what it means is your machine has logged 4 of the following errors, E001,E002, or E003. It is a lockout error and the machine cannot be used untill the problem has been repaired or the errors cleared. First lets look at the errors:
E001 fuser overtemp means the fixing assy has exceeded the manufacures maximun temp limits
E002 fuser temp dropout means the fixing assy has cooled below a set point during a copy session
E003 fuser no responce means the fixing assy didnt even attempt to warm up at power on
How to fix, most common problem is bad power setting 4 E002's either brown outs of brief power failures.
To clear the error, Enter service mode by pressing additional functions then the # button, use the left or right arrow buttons to scroll to #7 printer press set. again use the arow buttons to scroll to #4 printer reset press set.press the approprite arrow key under the YES to clear the error. unplg the copier and reboot. At this time normal function should return if not and it resets a E00 the nyou can assume either the fixing asy is bad or either the power supply PCB or DC controller is bad and it is getting E001,E003 errors. At that point id call a qualified tech to reserch the problem to avoid spending money on excess parts
Jun 05, 2008 | Office Equipment & Supplies
System Error: Code E000 Product manual: Turn off for 10 minutes. "if you cannot solve the problem" "call your service representative" I don't have a service rep. Please help. David717
I posted a note with a contact number..this appears to be a service level request
Contact Canon Consumer Products inactive_ln.gifcall_small_off.gif800-828-4040us.gifinactive_r.gif
Mar 13, 2008 | Computers & Internet
Canon imageRUNNER 2000 Copier Logo
1,320 people viewed this question
old marine
old marine
