Question about Ricoh Office Equipment & Supplies
I need help on how to disable the functional code sc545 with my dsm622 ricoh aficio 2022 copier
  • 31 Answers
Thats a fuser failure code. I suspect your upper roller is bad and has loaded up the temp sensor. The sc545 is dangerous to play around with, a possible fire danger has occured and the machine has locked you out. This requires a tech to inspect and reset. Ricoh does not allow qualified/certified technicians to disseminate this information out to the customers due to the dangers involved.
Posted on Jul 29, 2009
I had a functional problem sc 546 with my copier Ricoh 2022
Hi mkpack,
The error code SC546 that you're getting with your Ricoh Aficio 2022is related to unstable fusing temperature. There are two possible causes for this issue. These are, the thermistor is already defective and/or the crusted toner on the fuser roller. To reset this error code (SC564) you might to follow these steps:
1. First, press the yellow clear all button.
2. Then, select 107.
3. Hold the red stop button until the machine switches to SP Mode.
4. Afterwards, press the copy SP or system SP button.
5. You have yo shut your machine off and then turn it back on.
If after doing these steps and still you're encountering the issue you might need to remove the fuser and clean it. Also, you miht need to replace the thermistors. It's the black aluminum roll in the fuser unit.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Ricoh Aficio 2022 Black and White Copier
Ricoh Aficio 2022 Unit indicates to call for
You could reset all the counters but you should call a proffessional with a good mantenance KIT, your copier probably needs it...
Have fun!
Jan 04, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
Aficio 2019d error code sc 500
iam asking for help to solve an error code SC500 on my photocopier machine DSm622
Mar 16, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh 1045 showing code SC545. First was SC 546 and now SC 545 can somebody help?
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
Jan 26, 2010 | Ricoh Aficio 1035 Copier
Functioning problem with aficio 1033 or 2033,not sure, church cop
You must check the display for a code like SC-542 or something loke that.
Sep 17, 2009 | Ricoh Aficio 2022 Black and White Copier
I have a Ricoh Aficio 2022 which displays a service code SC545. Anyone know what this means. Do I need a tecnician to fix? Thanks Steve
This is a fuser overheating problem. I'd try to clean the thermistors and make sure they are touching the hot roller then use SP810 to reset the code. (clear modes, 1,0,7,hold down the clear stop key, enter COPIER SP mode,then go to SP810 and hit execute.
Sep 07, 2009 | Ricoh Aficio 2022 Black and White Copier
I still need help on how to solve or fix my Ricoh Aficio 2022 b/w copier functional problem error code sc545.the error code doesnt allow the copier to operate any time you turn it on. thank you
You can check the following.
1. hot roller thermistor is out of position or dirty.
2. Fuser lamp is broken.
3. Thermostat is open. (Like a thermal fuse, there SHOULD be continuity)
4. Clean and scrap clean the gold pins that connect into the copier. Sometimes they get corroded or bent slightly out of shape so they don't make contact with the terminals.
Aug 03, 2009 | Ricoh Aficio 2022 Black and White Copier
My b/w copier suddenly stop working when an error code sc545 appears on the screen and since then it has refuse to work. The moment you turn it on the functional problem error code sc545 appears on the...
You need to check 3 cause for that error:
- hot roller thermistor out of position
- fusing lamp broken (can you see the lamp going on at startup?)
- thermostat broken
If you are just a user, without any technical knowledge, i advise you to call a Ricoh Support Service.
Aug 03, 2009 | Ricoh Aficio AP410N Laser Printer
This is the code on the mach sc 545
Hello sir; The code sc545 means fuser unit temperature too low it can be reset;
press "clearmode" "107" and thenpress and hold "clear/stop" key untill display "copy sp" show up, then turn power off and back on.
Apr 09, 2009 | Ricoh Aficio 2022 Black and White Copier
403 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
