Question about Hoover Vacuums
Hoover powerscrub 50 leaking water from underside
  • Hoover Master
  • 1,545 Answers
The pump or a valve may be leaking and need replaced.
Posted on Sep 08, 2017
4 Suggested Answers
SOURCE: Leaking Hoover Steamvac
Mine did this exact and it turned out my pump was cracked.
Posted on Mar 30, 2008
  • 48 Answers
SOURCE: hoover rug cleaner is leaking water profusley
call hoover with your model and serial number ...this is a known problem with these and Hoover is replacing the tanks for free on defective units...you should have a new tank in about 7 days
oh and dont forget to flush out your solution pump regularly by emptying the solution and filing it with water then spray for about 3 min into a sink ...these pumps are known to lock up from soap residue when it dries..the pump is about $50 plus labor
Posted on Sep 28, 2009
supershadowx
  • 507 Answers
SOURCE: My hoover spinscrub 50 leaks when i put the water tank on
seems like a rubber seal isnt setting right with the tank or the seal is damaged
Posted on Feb 23, 2017
Feb 23, 2017 | Hoover Vacuums
Hoover f7458-900 leaking when placing tank on
Hello! Test the clean water tank to see if it is leaking. Fill the clean water tank with water on both sides. Hold the tank up and observe if water leaks from the valves underneath the tank. If either of the valves are leaking the clean water tank will need to be replaced. To order a replacement tank follow this link > Search Results. If the tank is not leaking, but the cleaner leaks when the tank is placed on it, this may indicate an internal issue with your pump. We would recommend taking the cleaner to a Hoover authorized service center. Follow the link to locate the nearest service center to you. > Service Center Locator Hope this helps!
Jul 26, 2014 | Hoover F7458900 Max Extract All Terrain...
Hoover spin scrub 50 leaking from bottom
Uh, may I encourage everyone to check the trigger under the handle...we went through taking the whole thing apart and it was just that the trigger was stuck in the open position, which poured the water out continually!
Apr 09, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
Water tank leaks
If the tank is leaking, when removed from the cleaner, it is not user serviceable.
Oct 01, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover rug cleaner is leaking water profusley from tank at the underside of equioment.
Sep 28, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My Hoover F5892-900 steam vac won't spray
run some CLR calcium cleaner through it (mix the water 50/50)
Aug 28, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Leaks when trying to use upholstry cleaner!
This is a common problem for these units, and is easily fixed.
Bad connection:
You may need to push harder on the coupling when attaching it to the machine
A leaky Valve
Manytimes the Valve you connect to can bust or crack where you cannot see it.
Remove the hood and inspect valve. (six screws on underside)
Leaky hose
The hoses that run to the Valve you connect to can come loose or crack.
Remove the hood and inspect hoses. (six screws on underside)
This machine may be leaking the whole time you use it, and you my just not be noticing.
If you are in a northern climate, freezing machines in garages or cars is the most common cause.
Jun 04, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover F5858-910 doesn't spray water
Hello dc42 & osuguy101. I suggest using a cleaning solution, 50/50 vinager/water, in the fluid tank to clean the ports. #2 Unit may have a fluid pump problem. Please update me on results.
Sep 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Clean Water Tank Leaks
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40471&thid=612034
Posted by Liviaa on May 21, 2008
The clean water tanks leaks. What's causing the problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Floormate H3000 Upright Wet/Dry Vacuum. You can down load the owner manual from the Hoover website www.hoover.com . It looks like the one of the holding or recovery tanks my not be in place, leaking, cracked or damaged, or the clear tube is leaking and needs replacing. I looked 2 the owner’s manual and it does not show the clear tube but the vacuum does come apart and just back track the clear tube and mark the screws when you disassemble the unit. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 21, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Either you have a crack in the tank and it is running down the indise of the handle and going out the bottom, or there is a water line off either under where the tank sits or under the top cover.
Mar 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
424 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
