We can not get the time signals in our area. I need to know how to reset the month, day and time manually.
See if these are the instructions..
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.lacrossetechnology.com/media/catalog/product/5/1/515-1316.pdf&ved=0ahUKEwi20reMi4jWAhUh24MKHcfpBeEQFggsMAI&usg=AFQjCNEsCBnwTraroE9N7qRdGqTzKjh3Fw
Testimonial: "No. That's a different company, and definitely a different clock. Fortunately I put the clock by the window and was pleasantly surprised when the signal did reach it and correct the month, day and time."
SOURCE: Acu-rite atomic clock squeaks periodically, why?
I had the exact same problem, and found the answer on the Chaney Instrument FAQ page. There's no real
solution, but here is the explanation:
Q: My wireless weather station periodically beeps, why?
A: Make sure that any alert and/or alarm features are deactivated
first. Constant, sporadic beeping is generally due to the unit’s
ability to detect a foreign radio frequency of another wireless unit
when that unit transmits a signal. Wireless devices that may cause
beeping but are not limited to these devices are; scanners; computers
w/wireless keyboard/mouse; or other wireless weather instruments.
Essentially, any wireless devices transmitting on a radio frequency
have the potential to interfere with each other. Limit the amount of
wireless devices to lesson the chance of interference. When beeping
occurs, one device will need to be deactivated.
SOURCE: Lost instructions for Lexon world time clock model Planete
to set the alarm, press and release the "alarm" button; then press and hold the "set" button until the hour begins to blink. press "adv" until
the hour AM or PM is correct;now press and release "mode" so that the minutes begin to blink. Set the minutes using "adv"; now press and release "set". Finally,
press and release "adv" once to bring up (or remove) the alarm icon. Then press"alarm" once to return to the main display.
To set main display, press and hold "set" until the hour begins to
blink; press "adv" repeatedly until hour AM or PM is correct. Now
press "mode" so that the minutes blink, and use "adv" to get the
minutes right; then press "mode" so that the next item begins to
blink; use "adv" to advance until it is correct, then press "mode"
so that the next item blinks, and so forth until you're all done.
Finally, press and release "set".
Testimonial: "It took a while to get a response, but the answer was correct and very helpful, thanks."
SOURCE: I have a casio G-Shock watch,And recently had a
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please.
SOURCE: need manual for g-force watch
This is not a manual, but will help you "set" the watch.
Press LIGHT briefly and your LCD will be back lit for 5 seconds.
Press MODE to cycle through normal, alarm, dual time, and stopwatch display mode.
Hold MODE for 3 seconds to enable the radio to receive time signals.
Press ADJUST to toggle year/time display. While in year display, pressing SET will alternate M-D / D-M.
Hold SET for 2 seconds while in normal mode to cycle through
world atomic radios (US/GB/DE/JP) push ADJUST to change, and SET to
continue. Next the language will flash (GB/FR/DE/ES/IT). Next is DST
on/off. Next, in order are hour, minute, second, year, month, day, and
12/24 Hr format.
(US only) Press SET to display timezone. The default is PA, use the ADJUST button to cycle through MO,
CE, or EA as desired.
Press SET while in alarm mode to toggle alarm on/off.
Hold SET for 2 seconds while in alarm mode to change the hour and minute with the ADJUST button.
If you need stopwatch settings or care and cleaning instructions, I can post them separately.
