Question about KitchenAid KGRA806PSS Gas Kitchen Range
KitchenAid convection oven - panel went black during self-clean SOS
I was self-cleaning my oven. After about hour the contol panel went black. The fan was still working but the door is locked and won't open and I have no screen. I tried re-setting the circuit breaker but that didn't work. My oven still won't open and the screen is still black, of course it's Thanksgiving day and I planned on baking ALL weekend. Any idea how I can fix this? HELP!!!!
  • 2 more comments
  • Marlalee Nov 22, 2007
    that sounds like it might just unlock the door, but if my panel is shot that isn't going to help me use my oven.
  • Lemon_Aid Dec 06, 2007
    Having the same problem. The repairman has been 4x, has replaced circuit board, control panel and thermostat. Still can't run a self-clean cycle. After about an hour, when the oven reachs full cleaning temp, it shuts down and we are back having no oven. Have yet to be able to run a cleaning cycle since we bought the oven.
  • atime4ever Dec 14, 2007
    I ran the self clean cycle for the first time and am having this same problem. I called Kitchenaid and they said to unplug for 20 minutes but still nothing....what should I do?
  • Anonymous Mar 18, 2014
    the oven stopped mid self-clean cycle and now the control panel is not working
  • 126 Answers
Turn power off. take back off range. manually unlock door. it sounds like your control panel is shot.after you have it unlocked turn power on try your oven
Posted on Nov 22, 2007
I have a frigidaire Electrolux self cleaning convection oven. I put it on self clean and it went fo over ten hours. now the door is locked and I cant open it. I tried to self clean and it wont start. The...
These ovens have notoriously bad control panel electronics. There is one control board for the oven that can be replaced or sent out for repair, $100 to $300.
Feb 03, 2018 | Frigidaire Ovens
Kitchen aid double convection oven - glass needs cleaning!
Had to remove the screws on the BOTTOM of the outside door, then panel came off after all the screws (inside oven door included) were off...
Reversed the order to put back on.. Cleaned (all) three glass pieces nicely... Now after reading the problems with the self cleaning part (doors getting stuck!) - I'm afraid to try mine!
Jan 22, 2010 | KitchenAid KESC307 Electric Kitchen Range
Kitchenaid double digital convection conversion oven keypad went out. Any ideas on the problem. Electric panel circuit breakers are okay. Sharon C.
I think these use the same controller board as the Jenn-air units, they have a weak capacitor (C3) on the control board (Timer/control Display). Remove the top panel and look for a discolored or leaking capacitor (usually black about 1/2" high 3/8" in accross). Replace the capacitor and the problem goes away, until next time you use the self clean cycle which seems to overheat the control board and ruin the capacitor.
Sep 23, 2009 | Electrolux 30" Built-In Double Electric...
My KitchenAid Supra self cleaning convection wall oven stopped heating after I had used the self cleaning program. I ordered a new heat sensory unit $80.00 but after I installed it the oven is still not...
There is a overload thermostat on the rear of the oven that will have to be replaced.
Self cleaning features are not recommended by most appliance technicians.
Self cleaning causes parts to fail often.
Feb 27, 2009 | KitchenAid KEBC107 Electric Single Oven
OVEN will not heat
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
Feb 24, 2008 | KitchenAid KEBC107 Electric Single Oven
Kitchenaid kgri801pbs
there is a thermal fuse in the back of the oven that more than likely has tripped during self clean poor air flow around can cause this power surges during self clean can too you have to pull the oven out and remove back panel to find it
Jan 10, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
Kitchen aid model# kgri801pbs
On most models, the door stays locked during a self clean, until the temperature returns to normal for safety reasons.
It sounds like your unit may have tripped a breaker during this self clean event. Check your panel for a tripped breaker. If the oven has cooled down, and the lock is still engaged, then we may have a different problem.
Let me know what you find out!
Oven will not heat at all after an interrumpted cleaning cycle (power went off)
There is a thermo fuse located behind the back panel of the oven. If the oven appears to be working but is not actually heating then this is the cause. The oven will have to be removed from the wall, power to the oven shut off at the main breaker and the back panel removed. the thermo fuse is just to the left and up from the center of the convection fan. It has 2 wires connected to it.
Jan 02, 2007 | KitchenAid KEBC107 Electric Single Oven
KitchenAid KGRA806PSS Gas Kitchen Range Logo
560 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
