Question about Nokia 6300 Cellular Phone
Nokia 6300 when m applying the time after few seconds it display that not enough memory
When i send video files via bluetooth from other mobiles to my nokia 6300, the message displays on the screen " file sending failed".Audio files received successfully but video files not. there...
Generally video files are bigger in memory than audio files.So firstly you check the memory status of Phone memory not for the mmc memory.And Check that the memory Card which you are using is less than 1GB Coz more than 1GB mmc is not supported in this model.Even if the mmc has enough space of memory however the size of the mmc is more than 1GB we cannot do this thing sometimes.So try to do what if not.
Apr 07, 2011 | Nokia 6300 Cellular Phone
Nokia 6300 themes not applying
its virus attack. use only authorized themes
May 09, 2010 | Nokia 6300 Cellular Phone
Theme on my Nokia 6300 resets every time I switch it off
move th etheme from memory card to your phone memory now apply it. it will be fine
Jul 04, 2009 | Nokia 6300 Cellular Phone
Actually I want to try apply the themes but every time I am facing a same problem of not enough memory. My Memory card have a problem. or my set having a problm. Please confirm
transfer some files from your phone memory to your memory card.
try applying again after you do it.
it is best if you store your pix, music and games on your external memory card to prevent your mobile phone to hang-up due to low on storage space.
hope this solved your problem.
regards,
-engrkoiled-
Mar 31, 2009 | Nokia 6300 Cellular Phone
My nokia 6300 is showing memory card removed but card is in.
I think believe it or not that there is moisture still in the phone. I dropped my 6300 in the bath and managed to get the battery out of it quickly enough and dried it out thoroughly and it works as before. The best thing to do is to take the battery out of it and leave it on a radiator on low heat face upwards for a few days. Then try it without the memory card first the re-insert the card and see if it registers. Hope this helps.
Oct 02, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 Problem with GPRS setting
nokia 6300 phone memory capacity is 7mb, if ur images, tones, vedios n recived files r there in phone memory plz move to memory card. 1 more thing if u have applied high quality theme then change it simple 1. it may solve ur problem.
Aug 01, 2008 | Nokia 6300 Cellular Phone
Unlock 6300
model Nokia 6300
IMEI plain: 354835/02/536220/4
Jan 12, 2008 | Nokia 6300 Cellular Phone
Switching on nokia 6300
Charge the battery,
Battery might have been discharged
Dec 07, 2007 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
