Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Fridge is fine but stuff in freezer is thawing I turned up fridge but that didn't help
  • pozhilantkm May 11, 2010
    which make fridge are you used? you try to deferasing use in deferasing key.
    Problem Solver:
  • 17 Answers
I have solved this problem before you can find the solution by looking up my profile the person was having a problem with his ice maker this is really the same thing it most likly has to do with cleaning out from under and behind the fridge to increase air flow
Posted on Jul 28, 2009
AMANA SIDE BY SIDE refrigerator/freezer . Freezer freezes intermitently, and then stuff thaws. Cleaned the botton coils, didn't help. unplugged and re-booted. didn't help
HI.intermitent faults r allways abit problematic .but run through some basics ok?1-after defrosted freezer works ok?2-how long for.if ok then all u can do is change defrost timer and t/stat one at the time or together.clean condensig unit thoroughly.good luck.ali
Jul 05, 2012 | Amana Refrigerators
Frigidaire model FRS24WNF. Will not freeze (except the lower compartment of the freezer) nor transfer cold air to the refrigerator. The back panel above the coils freezes up. Once I turned off the unit...
Of necessity, this is going to be a very LONG answer, BUT... it COULD save you from buying another fridge. There could be several causes for your issue, but the most likely is a blockage [usually a buildup of "frost"] of/in the duct that carries cold air from the freezer compartment to the fridge compartment.
Not all, but MOST refrigerators work by having two controls for the two zones [freezer and fridge sections]. The first control [an actual thermostat] is for the freezer, and is what actually turns the compressor on and off. The other control is for a "damper" in the duct [or, SOMETIMES controls an in-duct FAN] from the freezer to the fridge section.
The compressor system cools the freezer, and the refrigerator section is cooled by transferring colder air from the freezer.
The freezer control should be set to keep the freezer at about minus 10 degrees Fahrenheit to about zero degrees. Then the fridge damper control [usually the control with the letters A, B, C, and D] is usually set to about the MIDDLE position, hopefully to keep the fridge section about 34 or 35 degrees to a max of about 38 degrees.
SINCE you say that the FREEZER IS operating PROPERLY, I suspect that the DUCT that is supposed to supply cold freezer air to the fridge is somehow blocked, and this is usually caused by an accumulation of FROST [frozen water VAPOR] in the duct. Note, and write down the "settings" for BOTH controls. You'll need these later to restart the fridge.
Although the "fix" is a pain in the ____ it is not that difficult. Here are the steps to correct:
1. Get one or more ice chests/coolers.
2. Remove ALL contents from the freezer and place together in one, or if necessary two of the coolers well covered by bag ice to preserve the contents. Put a couple of bowls, or anything, in the bottom first to keep the frozen stuff above water from the melting ice. Then pack the frozen stuff very tightly with as little open space as possible. Then pour crushed ice on top. Several times a day, drain the melt water from the drain on all the ice chests, and as necessary, add ice to replace that which melted.
3. Do the same thing with everything from the fridge section.
4. Then turn OFF the refrigerator, and CLEAN both the fridge and freezer VERY WELL. IF you don't clean both the freezer and fridge WELL you will get mold, mildew, and probably an offensive odor!
5. Then PROP the freezer AND fridge doors open AT LEAST a couple of inches, or MORE if possible. This will allow warmer household air inside. IF you have a portable fan to blow house air into the fridge section that will cause the frost to melt faster.
In a house with no air conditioning, in the summer, the blocked duct should thaw in well less than 24 hours. If you have air conditioning and no fan circulating air into/through the fridge it could take 2 or 3 days, but in any case, after 3 days, you should be ready to test the fridge.
6. Plug the fridge back into the wall outlet, set both the freezer thermostat and the fridge control back to their original settings when the fridge was cooling properly. [AGAIN I remind you that, at the very beginning, make note of, and write down the settings for both the freezer thermostatic control, and the fridge duct control]
7. Place a thermometer on a middle shelf of the fridge [and if possible, one in the freezer also] and check it/them after about 4 to 8 hours.
IF a frost blockage was the cause of the failure, the fridge should now be cooling properly again and when the fridge temperature gets down to below 36 or 37 degrees [F], then you can replace all the stuff into the fridge. IF none of the freezer stuff has thawed, then that can be replaced in the freezer. IF any has thawed, then cook it properly, and you can freeze it again if you want.
I know this is a lot of work, BUT... it sure is A WHOLE LOT LESS EXPENSIVE than replacing a refrigerator that DOESN'T NEED REPLACING!!!!!
Jun 30, 2011 | Frigidaire Model: FRS3HR5HB
Freezer is over freezing/ice-ing up behind the board {where all the wires/fans/stuff is} thus not keeping fridge or freezer as cold as it should be.
You fridge has a broken defrost controller or a broken heating element.
Go to Roper online to find your parts and then see if you can buy them either at applianceparts.com or ebay. These are good cheap ways to get your stuff sent directly to you!
Then, unplug the fridge, thaw it out. And while its unpowered and thawing replace the two parts. Refer to your units parts diagram for parts locations. The controller should just be hiding down underneath or in back and the defroster heating element is usually under the freezer.
Good luck and be careful!
Feb 08, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
My express thaw won't turn off
You have a bad main control board problem . Stuff a shelf in the refrigerator section with crumpled up newspaper and leave running ( the ink in the paper absorbes odor . Takes several days to eliminate .
Jul 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not defrosting
Your defrost drain line is frozen over.Remove everything from the fridge and turn it off for 24 hours with the doors standing open.
The drain line will thaw and you will return to normal operation.
You could also turn the fridge off, remove the freezer floor panel and back panel. Take a hair dryer and thaw out the drain hole. Takes about 2 hours.
You decide which procedure to use.
Apr 23, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Cooling Problem with Amana Fridge/Freezer model ARS2663AC
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 05, 2008 | Amana ABB1927DE Bottom Freezer...
Moffat Freezer
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
Oct 14, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
104 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
