Question about Canon LaserClass 2060P Plain Paper Fax
My canon fax-b215c prints only triangles of various size across the paper. How do I reset it?
  • 1 more comment
  • info40740 Jul 29, 2009
    Thanks for the reply, it looks similar. Mine has function, set and resume buttons on the right. The dialing numbers are on the left. Faxes, copies and printouts all come out as small triangles. When printing out the same document again the triangles were in exactly the same place as the previous printout.
  • Ken Allen May 11, 2010
    Well I've never heard of this model. I'm curous about the fact that a laser Class 2060P is along side this querry. Does the B215C look like the 2060P? If so I can walk you through a machine reset.
  • 28 Answers
How to reset your unit. Please be advised that all of your settings will be erased. Htis includes any preset phone numbers and the machine name and phone number. Once you've done this the unit is back to factory settings.
By pressing data registration followed by the # sign the display should read SSSW#1. Press the up arrow until you see "Clear". Press Set.
Press the up arrow again until it reads. Clear all( or just All). Press set. Shut the unit off ( by pulling the plug and then start it up again and run a test.
Once again pleae be advised " This is a a technician procedure and you a fully responsible for your actions."
Posted on Jul 30, 2009
Shows receive in memory, check paper size
Either the paper size in the fax machine is wrong or there is not enough paper left to print the fax. Add paler and the machine will print the faxes held in memory.
Oct 10, 2014 | Canon Office Equipment & Supplies
MX-310 has fax's in memeory but keeps printing the first page of the first fax only. Screen says check paper size. When i push ok it only will print the first page over and over. How do I change it?
If your Canon MX-310 has been set up to print faxes as they are received, then what is actually in memory is a "received fax report". If you select a particular fax in this report, it will print the first page of the fax to remind you of the content.
Your Canon MX-310 will store fax documents in memory if:
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
Dec 04, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx700 fax report problems
after emailing canon support, the answer is this: 1) the fax paper size must be "letter" - 8.5-11". 2) reset all settings through settings menu. the fax will then print reports (and also every report that was not printed before).
Mar 05, 2009 | Canon MX700 Office All-In-One InkJet...
BARRIE@NORTONBARRIE.CO.UK
RECEIVED IN MEMORY
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will store it in its memory.
When the problem is resolved as described, the fax stored in memory is printed automatically.
bullet_s.gif Ink is low or has run out while receiving a fax: replace the FINE Cartridge.
bullet_s.gif Paper size/type setting is incorrect: correct the paper size/type setting.
bullet_s.gif Paper has run out while receiving a fax: load the paper and press the OK button.
bullet_s.gif Output Tray is closed: open it.
bullet_s.gif OFF is selected for AUTO PRINT RX: select ON.
bullet_s.gif You pressed the Stop/Reset button to cancel printing of a fax: press the FAX button.
Jul 18, 2008 | Canon PIXMA MX310 All-In-One Printer
I am using a fax machine Canon L80 and waiting to receive a fax ... it's blinking between and says "received in memory" and "check paper size" ... not sure what to do.
"Check paper size" means that the paper in the machine doesn't match the size selected in the setup.
To change the paper size:
1. Press the Function button.
2. Press the Data Registration button.
3. Press Set button.
4. Use up or down arrows until you see PRINTER SETTINGS.
5. Press Set button.
6. Use up or down arrows until you see PAPER SIZE.
7. Press Set button.
8. Use up or down arrows until you see type of paper in the paper tray (LTR, LGL, A4).
9. Press Set button.
10. Press Stop/Reset button.
Machine should now print out the fax that was received in memory.
Jun 20, 2008 | Canon Office Equipment & Supplies
Incorrect Paper Size Canon super G3 fax
Sometimes turning it off and on again fixes it. However, we started having a problem where it would print out one page after you powered it back on again and then give the "incorrect paper size" message. I've found that by either holding down the green button or repeatedly pressing it while it powers back on (and held until the first page prints) fixes the problem.
Jun 02, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Incorrect paper size
You may have a fax in memory that requires a larger size. Try putting legal in the tray and see if it prints out anything. Also, look in the set up menu to see if there is an "auto reduction" mode. That will make any over sized incoming faxes automatically print out on the size paper you have in the tray.
Nov 17, 2007 | Canon FAX-L380 Plain Paper Laser
"wrong size paper"
Change the cofiguration of the size in your fax machine see if accepts them then
Aug 16, 2007 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Canon LaserClass 2060P Plain Paper Fax Logo
77 people viewed this question
old marine
old marine
