Question about Samsung SGH-G600 Cellular Phone
Difficult to browse
I try to browse but the phone will say connection fail
"Failed to read the PC-FAX Phone Book"
Try this
Browse to Control Panel > Administrative tools > Computer management > Services and Applications > Services
Locate the following services:
1. Telephony
2. Network Connections
3. Remote Access Connection Manager
4. Remote Access Auto Connection Manager
Right click and select Properties. On the General tab, next to Start Up type, select Automatic followed by OK.
May 09, 2014 | Epson Artisan 810 AllInOne InkJet Printer
LG GW300 CAN'T BROWSE
i cant browse with the phone when ever i want to browse with it says conection failed.
Dec 18, 2012 | LG GW300 Cell Phone
Hi, I have Nokia 5800 XM, when I install new software or Themes it blocks my web browsing (wifi connected but can't browse). After reset it work. Kindly tell me easy way to solve this kind of problem....
Try re-installing the new software and see if that solves the problem. Sometimes firmware updates aren't complete fully and may cause some glitches to your phone. After doing so, you should see if you can connect to your internet on your phone.
If not, go to your settings and check out the network/browsing and your carrier network. It should be able to let you reset it. Start up your phone again and see if that helps. If all else fails, do a hard reset and uninstall the theme that you downloaded because that might be the problem.
Mar 06, 2011 | Nokia 5800 XpressMusic Smartphone
Dns failed
there's no problem with your broadband.. try to connect again to your wireless connection.. then if its already connected, go to menu > browser > settings > browser profiles then choose the name of your connection..
after choosing it, restart your mobile then try to browse on the net.. It usually happens to my phone mostly when i try to change connection (browser profiles) or when you get away for a long hours from your wifi range.. hope this may help..
May 28, 2010 | Samsung Star GT-S5233 Cell Phone
One touch access failing to connect to internet
Which operating system r u using?If its Vista, then d/l new Nokia PC suite which compatible to Vista.
Check settings option, if correct operator is selected.
Also, u r using a laptop, u can try connecting it in different USB ports.
It helped me too.
Feb 03, 2009 | Nokia N73 Cellular Phone
Connection failed error message
have you try to paired it on the other pc.. or did you try to use another blutooth..? let me know..
Jul 04, 2008 | Cell Phones
Cannot browse internet to samsung e250
thrw your phone in the wall and try again :))
Jun 30, 2008 | Cell Phones
Samsung SGH-G600 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
