Question about Nikon D80 Digital Camera with 18-135mm Lens
F-- appears in window with the 18-135mm attached to D80
I often see F-- appear in the window with the 18-135mm lens attached to my D80. By re-attaching the lens, the flashing F-- goes away, but can return intermittently. Please advise
  • 51 Answers
F-- means that the camera cannot find an apeture with the other settings that it is on put yur ISO on auto and put the camera in automatic mode and it should work but it might be a problem with the apeture in the lense, in which case it would be very hard to fix and you would probably end up desroying the lense in the process, if you did not go to a specialist.
Posted on Jul 28, 2009
My d80 stops functioning and shows F----!! Any help would be great thanks.
This is usually a lens issue. If the lens is not properly attached or the lens is a non-cpu lens it shows this error. If you are using an older non-cpu, you have to switch to M-mode to use it.
Jun 18, 2010 | Nikon D80 Digital Camera with 18-135mm...
My D80 fell from a foot n half above the ground level well packed in a good quality carry case few days back.uv filter attached to 18-135 Nikor lens cracked & lens cap was jammed. After carefully...
Hi, allow me to suggest using another lens to see if you still see the dark patches in the top corners. If not it is the lens, if so it is the camera. Either way it sounds as though something is maladjusted. Call Nikon digital 1-800-645-6689.
May 14, 2010 | Nikon D80 Digital Camera with 18-135mm...
Err message appears on the display of my D80.
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Nov 08, 2009 | Nikon D80 Digital Camera with 18-135mm...
I just purchased the Zeikos fisheye lense for my 50mm Nikkor lens and when I attach it, it doesn' take fisheye photos - just regular with some distortion around the edges... am I using this incorrectly?...
The 50 mm lens is a full frame lens, and the D80 is a DX camera. This means that the 50mm lens puts an image out that is bigger than what the D80 can "see". The good part of this is that the D80 (and most of the other Nikon DSLR's) use only the image from the center part of an older lens. The bad part is that if you put the fisheye filter on it, the fisheye effect that is mostly seen at the edges of the lens doesn't show up on the D80 sensor. If you could put the fisheye filter on a DX lens, it would give you the full effect.
Sep 24, 2009 | Nikon D80 Digital Camera with 18-135mm...
Zoom lens is "locked"
Is there a little lock switch on the lens?? My Nikon lens all have a tiny little lock and if it accidentally gets pushed into lock position it will not zoom. Barry Brown www.coralreefphotos.com
Aug 18, 2008 | Quantaray Tech-10 70-300mm f/4.0-5.6 Lens...
Nikon D80 Digital Camera with 18-135mm Lens Logo
152 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
