Question about Sharp AR-5316 Advanced Digital Imager Copier
Error code "L" & "1"
Hallo sir...
I have problem with my copies SHARP AR-5015
The problem is Error code "L & 1" on display.
Thanks with your help...
  • 143 Answers
L1 indicates a scanner feed problem. Make sure the scanner isn't locked in the shipping position. It is underneath the scanner where the paper exits the machine. Look for a plastic dial and turn it one way or the other.
Posted on Aug 01, 2009
    Scholar:
  • 136 Answers
Yes I like to confirm that "Wallen" is correct L1 is a Scanner Lock
however, let's take one more step shall we. What I like you to do si lift the ADF (Feeder Unit ) thats where you place copies on the glass.
See if you can see the lamp/scanner moving back and forth. If it doesn't then you have scanning issues. If you turn off and then on the machine and see the scanner moving yet an "L1" code still exist then you need to contact a Authorized dealer like ourselves to repair this issue : Let the service provider know that you have a Home Positioning Sensor" problem which is causing an "L1" error code.
If you need help in repairs ,our website is:
http://www.copierspluswwllc.com
Posted on Oct 10, 2009
Error code h-3 on my sharp ar 5015
Basicly, you have a problem with the fuser unit.
Aug 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharpe ar-163 with error code u-240
Hello sir; The error code you display is CRUM communication error.
Feb 05, 2010 | Sharp AR 163 Copier
I am using Sharp AR-5316E copier (It makes noise)
Yes, Toner waste sump over filled; 100%!!! To confirm it, remove Toner cart. & make copy; I found same problem in Toshiba eStudio161, which is Sharp AR163, 5015, 5020 & 5316(all are same)
Jan 04, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M208N with OFH4-00 error code
Hello sir; This code require simulation to reset the procedure as follow; press "#", "interupt", "clear", "interupt", then enter 14 press start. turn power off and back on, then all set.
Sep 27, 2009 | Sharp AR-M208N Copier
Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Aug 19, 2009 | Sharp AR-M205 Copier
Sharp AR-150N displaying F2 Error code.
Hello sir; I can't find this error code in my manu please check your code again.
Aug 12, 2009 | Sharp Office Equipment & Supplies
Error code 1 and L flashing alternately
Hello sir; I like you check the scanner unit, the mirrow does move out when you make a copy, you may easy to find out what cause the mirrow not move out.
Jun 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Apr 28, 2009 | Sharp AR-407 Copier
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
Sharp AR-M350N/H5-01
Hi, to reset H5 follow this sequence: P, *, C, *, display should read 'enter simulation', enter 14, print, execute, yes. Should re-boot if not switch off then on.
Cheers
Andy
Jan 24, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
385 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
