Question about Sanyo PLC-XU30 LCD Projector
Is there any way to check the bulb life on a Sanyo PLC-XU30 projector? I know some projectors have an option on the menu screen which lets you know how long the bulb has left. Its just that i bought it off ebay and forgot to check out the bulb life. Also does this model have an eco mode (or something similar which saves bulb life). As you maybe able to tell, there was no instructions with the purchase
On my XU 55 the trick to read the lamp hours is to press and hold down the power button in about 20 seconds when the projector is turned on. there will come a window in the upper left corner that tells about total hours and lamp hours. the window will disappear quite fast, so one might need to do it twice.
Posted on Aug 27, 2009
  • 2,236 Answers
Go into the menu and there should be an info menu option or under image settings it'll state the lamp hours.
Posted on Jul 31, 2009
I cannot get my remote to work with my Sanyo PLC-XE30 projector
I would first try changing the batteries in the remote and verifying that batteries are in the right direction (+ and - terminals line up).
Once that is done, try pointing the remote right at the infrared sensor at the front of the projector...the black plastic circle on the front of the projector.
Mar 04, 2011 | Sanyo PLC XU30 Multimedia Projector
Replaced bulb, shuts off after about 15 to 30 seconds, any ideas?
from experience that when a projector shuts down that quick, a fan was the culprit. If you had a lamp exploded recently, there is a chance a piece of glass get stuck in a fan.
Apr 18, 2010 | Sanyo PLC XU30 Multimedia Projector
I need a service manual for a Sanyo PLC-XU30
Go to Sanya website .click on support ,put in you rmodel# and they will let you download it free.
Jan 23, 2010 | Sanyo PLC XU30 Multimedia Projector
How do I change the light bulb in the Sanyo pro traX multiverse projector
unscrew the lamp door on the bottom of the projector, unscrew the lamp, remove the lamp, replace with new lamp, screw in, replace door, turn on, and reset lamp counter (menu-settings-lamp counter reset-yes)..
Nov 03, 2009 | Sanyo PLC XU30 Multimedia Projector
How do i change the bulb in a sanyo pro xtrax multiverse plc-xu30 prodjector
remove the screw on the door on the bottom of the projector for the lamp and pull out the old bulb and replace
Apr 16, 2009 | Sanyo PLC XU30 Multimedia Projector
Sanyo plc-xp46 lcd projector
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on
Feb 10, 2009 | Sanyo Projector Lamp for PLC-XU100,...
Ghosting image
Hi there
I'll bet you any money that the problem is cable related.
We often get this problem and by swopping the cables we normally get the problem solved.
Hope this is of help
Mar 26, 2008 | Sanyo PLC XU30 Multimedia Projector
Plc-xu30
This is called "keystone adjustment". If you still have the owner's manual, it will describe how to do it. If you don't have the book, look on the button console on the projector, or on the remote for an icon that looks like a rectangle that is either narrow at the top or narrow at the bottom and press it. That will get you in the control. If there's no button, you will probably find it on the set up menu. It's pretty easy to do the adjustment, one way makes the image narrower at the top, the other makes it narrower at the bottom. Some older projectors just have a **** on the unit that changes the angle of one of the mirrors inside to accomplish the same thing. The reason for this adjustment is to compensate for the distortion of the image caused by a projector mounted near the ceiling and pointing down at the screen, or sitting near the floor and point up at the screen.
Mar 10, 2008 | Sanyo PLC XU30 Multimedia Projector
Sanyo PLC-XU30 LCD Projector Logo
232 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Electro Med Services...
k24674
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
