Question about Bosch 33618 1/2" 18v Cordless Drill Tool Only + Case
How long do I charge my 18 v PSR bosch cordless drill for as it only has a green light on it and it stays on when I put the drill onto the charger
  • 25 Answers
About 180 mins or an hour and a half. if the light does not change, just make sure you put it properly on the charger base and time it for charging. Disconnect it after you are done. Usually, the light on the charger is just an indication that it is powered on.
Posted on Jul 28, 2009
  • dpreyes Jul 28, 2009
    about 180 mins or an hour and a half. if the light does not change,
  • Martin May 05, 2013
    Make sure the battery clicks into the charger - the light will blink when in correctly
Bosch PSR 1440 power drill. How do I know when the battery is charged?
Tracey,
There should be a legend on the top of front of your charger that should explain the light sequence for the charging process.
May 15, 2015 | Bosch Drills
How to remove necessary parts from Bosch PSR 12 cordless drill to recharge the battery?
You shouldn't have to remove any parts, except the battery itself, to charge the PSR12. I did find a breakdown of your drill that shows a 'Battery Retaining Clip' that is a heavy, u-shaped wire that goes into the front of the housing section just above the battery. It may have to be removed to get the battery out.
Nov 25, 2012 | Bosch 12 Volt Cordless Drill
Will 18 volt black & decker charger over charge battery
Hello Howard, There are two different kind of cordless drill chargers. One is a smart charger that will not overcharge your battery. It usually has a stand alone base that the battery plugs into and sometimes may have a red and/or a green light to let you know it is charged. This charger will stop charging when the battery is fully charged after an hour or less. The other one is a dumb charger that can overcharge your battery if left on the charger too long. This charger usually has a square or rectangular transformer that plugs directly into your wall receptacle. This charger may take up to eight hours to fully charge your battery and will continue to charge until you unplug it.
Oct 04, 2011 | Black & Decker & Cordless Drill
My ryobi 14.4 v cordless, when i put the battery in the charger the yellow and green light both stay on and does not charge. this happens with both chargers and battery packs
If i have this striaght two chargers and the green and yellow lights are on and the batterys will not charge and there 14.4v batterys correct . Then the batterys must be no good unless bolth chargers are bad and have the same problem witch is exterimly unlikely. most likely the batterys and are NG.They don't do well if left in cold condutions or hot for that matter but cold is worse . 14.4 V is is an unasul size and if its not a lithuim ion battery its going to be obisilete and unavaible soon if not already . Ihad the same problem with my RYOBI 7.2 volt can't get the batterys for under a 100 dollars thats one and a speical order i paid 39 dollars for the gun and 2 batterys . They make the money off resale on batterys . And you can do far better then RYOBI for a screw gun now a days
Sep 09, 2011 | Ryobi 18v Cordless Drill - P206 18 Volt V
Green light stays on when charging the red light does not come on
The battery is dead, and the charger will not not charge it. You need to purchase a new battery.
Apr 08, 2010 | Black & Decker 18 Volt Cordless Drill...
Bosch cordless drill PSR 120 12V will not charge up.
About the only indication if the charger is not working is when you put the batteries into the charger and no lights come on. This indicated that the charger is faulty. If the lights come on it is most likely the batteries. The best thing to do is take the batteries and charger to a Bosch service center and they will test them for you. Most will do this for free.
Nov 10, 2009 | Bosch Drills
18v Litheon drill charger won't charge battery. Green light stays solid even though battery is dead.
It could be the battery or the charger. Best thing to do is find a Bosch service center and have them test them. The litheon stuff is fairly new, there is a good chance it will be on warranty.
Oct 17, 2009 | Bosch Drills
Have a Fire Storm place battery in charger green light comes meaning full charge but place in drill there is no charge. Is it a new battery, or new charger, or new drill required
if you have one check the battery and charger with a meter. if there both fine check the prong's on the battery and the power tool. if charger is'nt charging check the fuss in the charger.. good luck let me know.
Oct 16, 2009 | Black & Decker 18 Volt Cordless Drill...
14.4V Drill Battery Will not Charge
The battery is 14.4 volts so the charger should be 14.4 volts.
Jun 26, 2009 | Makita 3/8" Dr. 14.4V Cordless Drill Kit
Bosch 33618 1/2" 18v Cordless Drill Tool Only + Case Logo
1,683 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
