Question about HTC Touch Cellular Phone
DISPLAY IS NOT COMING
After plugging the charger it gets heated and display is not coming
Acer aspire 5100 when a laptop does not start with power plug on and no battery what could be the issue
Do you have a voltmeter? The first thing I would check is to see if you are getting 19VDC coming out of the charger. The on then off when you have the battery in sounds like your battery is almost out of juice and the fact that nothing happens when you plug it in without the battery indicates to me that your power adapter is not working.
Jan 31, 2017 | Acer Computers & Internet
Please I hope someone can help me. The laptop is stuck on the reboot and select proper boot device screen.. i can get to the bios though
unplug your laptop, remove the battery and wait for three minutes. then install back your battery and power on. right after you power on your laptop press shift key together with f9. release the keys when the laptop begin to boot. follow the instruction on the display.
Sep 04, 2015 | ASUS X551MA-DS21Q 15.6" Notebook - Intel...
My kindle fire hdx has been plugged up for 11 hours and still not coming on. Is it broken?
When you plug it in, does it display that it's charging? If not, it might be a problem with the charger.
Aug 25, 2014 | Tablets & eReaders
Samsung GT-S5233W display is coming white and when charger is connected samsung tone is coming pease help
replace ur lcd and if it pessists flash it flashfile details sms the rainmaker on 00263777770767 he will assist you.
Feb 18, 2014 | Samsung Cell Phones
NO DISPLAY
Dear user,
Please ensure the battery has charge, plug in charger for 15 mins and try putting phone ON, if it does not coming on it means phone has hardware problem
Aug 22, 2012 | Nokia E63 Cell Phone
I accidentally put my cell phone in the dryer for 20 minutes with my coat (my coat was dry). the battery was wasn't connected when i retreived my phone but when i attached it the phone wasn't working. is...
Intense heat will damage or destroy the Battery. Also, heat will damage or destroy the Liquid Crystal Display (LCD) by melting the crystal.
Try the phone with battery charger connected. With Charger connected and powering the phone, try to turn on. The Back light is usually driven by LED s which are robust and can sustain the Dryer heat.
If the phone back light comes on, the the phone electronics is probably OK and will still work as a phone.
The Battery can be replaced, but there is no easy way to replace a bad display.
So, Power with Charger, look for light, try dialing without display.
  • If above suggestions fails then ,please approach an authorized dealer / service center .
Hope this helps.
Mar 15, 2010 | Lenmar Lithium-Ion Battery for Select LG...
HI I have a dell Vostro 1510.There is a problem with my system since yesterday .when I have connected my latop to the cahrger My laptop swiched off .And I am never again able to restart it.Later observed...
dear,
did u check the charger itself...its important ...
if you have multimeter then unplug the charger from laptop and plug the mains from socket to th charger plug and check the output DC voltage..is it coming, if coming then is it constant or varing ...if varing then u have to check the charger inside by an expert...
if its ok then remove the battery of the laptop and plug the main to charger and charger to laptop and then check its performance by switching on laptop...if its work then battery issue....
Aug 03, 2009 | Dell Vostro 1510 Motherboard System Board...
China Make N95
dear,
charge the phone with its own charger. dont use universal charger or other nokia mobile charger. china mobile have this problem. so charge the battery with the charger that came with it. hope ur problem will be solved.
regards,
Jul 23, 2008 | Nokia N95 Cellular Phone
Battery suddenly will not charge.
the charger has gone bad; get a new one at sonyericsson.com
Mar 05, 2008 | Sony Ericsson Z610i Cellular Phone
HTC Touch Cellular Phone Logo
21 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
