Question about Sony SDM-HS95 19" LCD Monitor
Repair or Replace screen on Sony 19
Can a 3/4 scratch be repaired or will the LCD screen need replacing? The scratch doesn't conflict with anything yet.
0 characters
1 Points
LCD Screen Broken
You find any authorised service cemntre at your place and get it replace.
Or you go to any good service / repair centre and replace the screen
Jul 23, 2011 | Hannspree 19" Widescreen LCD Flat Panel...
The display on the screen is jumping and does not hold still. Can this be fixed or is it time to replace the monitor?
A "previously-owned" 17-inch LCD screen probably will cost $30 to $50.
A brand-new 17-inch LCD screen is hard to find -- probably, nothing less than 19-inches is being sold, for $100 to $150.
An audio/video technician will charge $60 to $75 per hour to try to repair your LCD.
So, responsibly recycle (or "free-cycle") your old screen, and purchase a new 19-inch screen.
Jun 20, 2011 | Gateway FPD1760 17" LCD Monitor
LG Flatron L193ST. Relatively old model. The monitor screen stays dark upon connecting with a power socket and the power LED blinks rapidly in a yellowish amber colour. A quiet pulsating sound emits from...
L193ST common problem!! solution is only by replacing 2 capacitors 470uf 25v located on the power supply pcb inside the lcd they are neer the long cable connector
remove the 8 screws from the lcd back panel including the holder screws,
use a thin metal stick like a knife and insert it between the back pannel and the front black panel but slowly remove the black panel not to scratch it
remove the metal protection panel 4 screws
the power pcb becomes visible
remove all connected plugs and the 3 screws
desolder the 2 capacitors and replace them
assemble back your lcd and enjoy
30min time of work 5$ cost
Sep 06, 2010 | LG FLATRON L1950B-SF 19" LCD Monitor
What causes a dark screen and a flashing power button for a HP Pavilion F1903 19" flat screen monitor?
Probably find the screen inverter has failed and needs replacing. Can be a fiddly job as you have to dismantle the monitor so take it to your repair shop if you're not familiar with this type of repair.
Apr 28, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
My Son threw his sippy cup at my 19" LCD Flat Screen.
Did the screen get cracked?
If so, I would most likely suggest replacement than a repair.
The LCD panels are not cheap.
Sorry for the bad news.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
Mar 15, 2010 | Gateway FPD1975 19" LCD Monitor
Samsung 914v 19" LCD pixels went out
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 31, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
My monitor cuts out after about four seconds
ludwighro805, If Lucky Goldstar warranty not valid option, or LG cash+ old unit refurbished swapout then you will need to repair unit or contract out the work to technician that fully understands failure mode of unit W1934S. Get into my FIXYA profile and READ, READ, READ. Your unit good candidate for repair. Your unit CLASSED as "BLACK" or "BLACK and BLANK" screen failure due to possible POOR factory reflow soldering process. If you do the research you may even want to try a DIY fix. If this info helpful, please rate this response on FIXYA. Good luck with repair. Explore your options before doing anything. Do an additional comment if you still require assistance. 12fixlouie on fixya
Jan 05, 2010 | LG W1934S-SN 19-inch Widescreen LCD...
Hyundai 19
yes any electronics shop should be able to replace the bad capacitors for under $55 dollars. common problem
Jan 01, 2010 | Hyundai Electronics Hyundai LCD 19"...
Screen turns on for a second then turns off
Your power supply is blown. If you have some repair knowledge then pull it apart and look for caps that have raised or bubbled tops. They need replacing I do this repair all the time. If you don't want the monitor please let me know I will pay for shipping. I repair them for the school.
God luck.
Mar 15, 2009 | Sony SDM-HS93 19" LCD Monitor
Repair monitor screen
no u cant u simply have to replace your glass of the monitor visit a computer store
Oct 25, 2007 | NEC MultiSync FE991SB 19" CRT Monitor
Sony SDM-HS95 19" LCD Monitor Logo
Top Sony Computer Monitors Experts
Lala Alonsi
Lala Alonsi
ray gallant
Are you a Sony Computer Monitor Expert? Answer questions, earn points and help others
