Cannot tune in programmes I go to menu which brings up screen picture, audio, time but skips on tuning into progs and goes to options. Please help.
  • 10,594 Answers
Select TV as input source by TV remote or push Channel button on remote then go to TV Menu. That will enable Tuning menu in TV.
Posted on Jul 28, 2009
HD option no longer appears on screen
Some settings have got changed. Please go to menu and try resetting it.
Jul 25, 2012 | Televison & Video
How can i autotune my soney trinitron tv iv lost the manual
Hello
Enter menu, and select the [autotune or auto search] function with the help of Prog+ Prog- and Vol+ and Vol- buttons. After that function highlighted press Vol+ button once and release. The TV will tune and store automatically in its memory, all the transmitting stations at that time, and after tuned the entire band it will finish tuning and will display the first channel. You must select auto tune for this. Not manual tune or fine tune functions. A horizontal bar will run across the bottom side of the screen indicating that the tuning process is in progress, and it will reset three times to zero and will continue tuning. It is due to the auto band selection is done inside the microcomputer of the tv. No other functions will response anymore, till autotune process is completed. Ok.
Oct 19, 2010 | Sony Televison & Video
Options to auto-tune or manual re-tune are greyed
Problem solved!!
According to the Sony website I needed to get a software download in order to fix this problem. I found out how to do this from the manual and realised that the re-tune menu I was looking at was for analogue only. The pictograms onmy remote control are a blurred but the manual helpfully provided a picture showing the correct program "info" button (next to 0) which has options to look at other things, including a "detailed set up" menu on the blue tab, which provides options for software download and re-tune of digital channels.
Incidentally, I discovered that my TV model was not quite as quoted above - it is KD-28DX200U, but expect the same process works for other oldish models.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Unable to tune tv
next time you are moving a tv, make sure that
a tv is on a soft surface,
there is a dry joint on the card because of vibration onthe card.
take your tv to a w/shop for service.
that problem will be over. ok
Nov 23, 2008 | Goodmans 257NS 20" TV
Can not get the image back on my astar hdtv when I choose the option
First check Tv menu comes on screen?
Connect DVD Player at any a-v input and confirm picture on tv. This will confirm that tv has no problem except in tuning circuit.
Now check Antenna / cable hooked up in RF input of tv properly.
Perform Auto-Search / Auto-Tuning / Auto-channel on TV menu and tune all available channels.
Still blue screen? means TV Tuner looks bad.
Sep 16, 2008 | Astar Televison & Video
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
GPX clock radio clock question
I emailed the company and they sent a pdf of the manual back the same day.
partsinfo@dpi-global.com
Jun 06, 2008 | GPX CRCD6306DT Clock Radio
Tuneing in my tv
Hi There
Came to this site with the same problem - finding no answers I went back and tried again
Hope this isn't too late for you. Press the 'MENU' button - you'll get the picture sound etc - keep your finger on it and you get 'INSTALLATION' at the bottom in white!
Hey presto! use the <&> to get into the sub menu and away you go!
Hope this was some help
(P.S. use the menu button on the front of the set if the remote button fails to bring up the installation option = it is behind a flap between the on/off button and the indicator lamp under the screen)
Mar 28, 2008 | Hitachi HL01453 Remote Control
Tuning Sanyo VCR
Press both channel buttons simultaineously for 3 seconds it will automatically tune your programmes press ok when ok flashes on vcr screen display
Nov 04, 2007 | Sanyo DS27910 27" TV
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
Electro Med Services...
