Question about Nokia 5300 Grey Cellular Phone
NOKIA 5300 SPEAKER PROBLEM
Hey im here again
i nid help with my nokia 5300
speakers
it sounded soooo bad...
HELP!!!
No sound
open it, see the speaker, is it well located?
Apr 18, 2010 | Nokia 5300 Grey Cellular Phone
My Nokia 5300 speaker problem
hi,
i think you had given to unauthorized service center for change the housing. they did not connected your mic properly. otherwise they damaged your mic. you can go to nokia priority center and give for service. they will rectify this problem for you..and this is not your speaker problem, it is mic problem only...
Thank you...,..
Aug 22, 2009 | Nokia 5300 Grey Cellular Phone
Can't hear anything in "normal" mode, only in loudspeaker mode.
You need to isolate the problem. Try connecting a headset first, if you hear music coming out of the headset, then there's a problem the speaker and needs to be repaired.
But if there's no sound coming out of the headset either, then you need to check the phone or sound settings of the phone. You may simply navigate it or refer to the user manual.
If you get the same problem after modifying the settings, then bring it to the Nokia Care Center for repair.
Hope this helps and have a great day!
Jul 21, 2009 | Nokia 5300 Grey Cellular Phone
Nokia 5300 can't hear anything
pls change the speaker of your phone the loud speaker is fine and the earing speaker is gone
Jul 10, 2009 | Nokia 5300 Grey Cellular Phone
Forgot security code nokia 5300
Hi Friend,
Kindly note down the Master security Code
1257314120
Regards,
Ayyasam
May 31, 2009 | Nokia 5300 Grey Cellular Phone
Loud speaker problem in my nokia 5300
That is the biggest con of Nokia 5200 and 5300.I've read reviews that Speakers emit noise in just 3 days of heavy use.Only solution is to use a headset:)
Apr 05, 2009 | Nokia 5300 Grey Cellular Phone
Can we use the home theatre to nokia 5300. like big speakers and other speakers.......
yes. i connected it with my 2.1 computer speaker with the use of universal jack(got with the cell phone indeed),every thing worked fine.
Jan 23, 2009 | Nokia 5300 Grey Cellular Phone
Mobile speaker
Try adjusting the volume using the volume keys on the right side of the phone, try to lower it then make it higher if you are able to adjust it means there is no problem with the volume.try to have it checked in a repair shop cause in some cases the speakers migt have a defect or needs to be cleansed.
Jan 07, 2009 | Nokia 5300 Grey Cellular Phone
Loud speaker is not working
Hi
You have defective loud speaker.. repkace a new one
Thanks!
Oct 17, 2008 | Nokia 6300 Cellular Phone
NOKIA 5300 - no sound
Thanks. It worked. The speaker cover had come loose and I snapped it back into place. Before that i did check the equaliser and the night before the settings and profiles. was going to chuck the phone back at the guy who sold it to me,
Thanks FIXYA.
Jan 01, 2008 | Nokia 5300 Grey Cellular Phone
Nokia 5300 Grey Cellular Phone Logo
232 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
