Question about LG BG8000ER Air Conditioner
Heat load calculator program
I need a heat load calculator program where can i find it? i need it to make it more easier to calculate all heat load in design for comercial
building,
    Champion:
  • 363 Answers
Try RSMEANS.com
Posted on Jul 28, 2009
Need help setting the calculator to use in a daycare food program for calculating portions CFX-9850GB plus
First solve the problem by hand. Once you understand the solution it would be easier for you to implement it.
Dec 21, 2016 | Casio Office Equipment & Supplies
I have a Casio fx 9750Gii.i cant write long program because i have already used all alpha key memories.how to continue writing the program
I believe you must rethink the design of your program
If you have several inputs that lead to a single result you want to keep for further calculations, enter the inputs, calculate your result and store in a variable. The intermediate variables can be set to zero (by precaution) and reused.
Use functions, and subroutines. Usually, in well designed programs, the scope of a variable defined inside a function or subroutine is local :It can't collide with the same name used globally (global scope). If a variable is no longer needed destroy it and reuse it.
Feb 23, 2014 | Casio FX-9750GPlus Calculator
How to write long programs after using all alpha keys memory with casio fx 9750Gii
Use functions, and subroutines. Usually, in well designed programs, the scope of a variable defined inside a function or subroutine is local :It can't collide with the same name used globally (global scope). If a variable is no longer needed destroy it and reuse it..
Feb 23, 2014 | Casio FX9750GII Graphic Calculator
I'm unable to send to, or receive from, my PC files.
Kermit is a protocol designed to allow two computers to communicate with each other.
The HP 50g is not compatible with Microsoft Word. You can write programs on the 50g, transfer them to the computer, and transfer them back, but you cannot edit them in Word.
There are other PC program that will let you write and edit 50g programs. There are also many communication programs. Take a look here.
You may want to consider getting an SD card (and if necessary, a card reader for your computer). It's a lot easier and faster to transfer data and programs using the SD card than the wired connection.
Jun 27, 2012 | HP 50g Graphic Calculator
A program slows my Ti down, but only after 5 sec.
Your program is depleting the RAM. You may be creating too many graphics and when you no longer need them, you are not erasing them from inside the program. 24KB is easily used up. It is also possible that some calculations(if you are doing calculations?) are not converging. Recursion can be quite involved and they take too much time.
What can I say? Even a small program badly designed (no reflection on your abilities) may misbehave after a few iterations.
Mar 04, 2012 | Texas Instruments TI-84 Plus Calculator
How do I take a screenshot of the work done on the calculator? I have a casio 9860 G II
I would like to help but currently I do not have the time to describe a flawless procedure to get the screen of your calculator on the computer.
However I do have an easier procedure for you: Use a Casio Emulator program. It is s program you run on your computer that mimics the working of your calculator. Fortunately for you, Casio has one such program for the FX-9860G ( also known as Graph 85 in Europe).
Here is a link to download it
http://www.planet-casio.com/Fr/logiciels/voir_un_logiciel_casio.php?showid=19
Once you get to the page, click on the link in GRAPH85emulator.exe (2.6Mb).
Execute it on your computer anytime you want to save some screen to the computer.
Perform the calculations you have to on the emulator. Then right click in the emulator area and select the option Capture Screen.
Open an image editing program (paint, Gimp or what have you and copy CTRL V in the program window.)
Mar 03, 2011 | Casio FX-9860G Graphic Calculator
The memory button on my TI-84 Plus will not function
If you connect it to the computer using ti connect device explorer you can try to do everything from there. Manage your memory. If you saying the plus sign is broke too, because it is the memory key too. I wonder if you "+">a would work. Just 2nd recall "a" when you need the plus sign. You can store it in any variable you want. Setting up systems to operate your calculator's memory management can be done on command or Entry Line. Much easier with Ti connect. You don't really need the plus sign or memory key to run very good memory management programs. Just remember to download from this site my ti 84 plus silver manual on how unarchive and run programs. I really don't recommend taking the calculator apart, they usually end up broke at that point.
Sep 18, 2009 | Texas Instruments TI-84 Plus Calculator
Books on TI-30Xa
Honestly, you do not need any additional books to learn how to use it.
You can however design your own small programs to do certain calculations that require more than one step; Exemple: calculate the area of a cylinder knowing its height and radius. or the volume. you will have to use the memories to store the data and the internediate results.
Concentrate on learning how to use it efficiently on your exams.
Hope it helps
Aug 26, 2009 | Texas Instruments TI-30XA Calculator
I need to load formulas such as trig identities, derivatives, ect. onto my calculator. How do I do that?
It will not do you any good to clutter the memory of your calculator's memory with formulas that it cannot use. You might as well write them on paper. Teachers are aware of the possibbilty of cheating, and calculator manufacturers are now to designing graphical machines so that the teachers can disable certain features during examinations.
Hope you are not too disappointed.
Apr 04, 2009 | Texas Instruments TI-83 Plus Silver...
Downloads
can u down load excel to the fx-9860g
Jun 08, 2008 | Casio FX-9860G Graphic Calculator
LG BG8000ER Air Conditioner Logo
323 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
