Question about Cell Phones
My iphone drains quickly . i would charge it for several hours and after 5 hours without using it the baterys dead. even if i truned it off after fully charging it, after several hours its dead again.plz help
Iphone wont charge
The battery might be damaged, but in most cases you can just let it be plugged in like you normally do. It doesn't show "recharging" because it has been too drained.
Turn on your phone after 15 min. in the charger.
If it still doesn't work, then you have to ask a store that supports Iphones.
Aug 06, 2014 | Apple iPhone 4S
My iPhone battery drains quickly
Hi, many things can contribute to battery drain, what model and IOS do you have?
Oct 31, 2013 | Cell Phones
My iphone powered down and wont turn back on?
if you drained the battery to "minus" it needs to be charged some time even to be ready to turn back on..
pls charge it..leave 2 hours and than try it again,it will come..(unless your battery is completely dead.)
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 09, 2011 | Apple iPhone 3G
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
My Iphone was working fine until an hour ago when I accidentally let the battery drain. Now the low battery icon has shown for 1 hour without the Iphone coming to life. I need my iPHONE as i live remotely.
I know how desparate this feels - try powering it off completely and remove / replace the battery - make sure the charger is connected securely and try again - you should be able to use the phone whilst it is on charge. If the charging symbol does not appear when in charge mode then the charger itself may be faulty. Try hooking it up to a USB cable from your PC - it should still charge but not as quickly.
Mar 18, 2011 | Apple iPhone Smartphone
My iphone is totally dead...it cannot charged at all...even i connect in pc doesent work too...
the charge port its dead change it but first try a batery from a friend because can be the firmware
May 13, 2010 | Apple iPhone Smartphone
New battery loses charge to quickly only lasts 24 hours have tried another still the same problem have fitted phone cover
For better battery performance, perform the following tasks,
1. Switch off the bluetooth. If needed put into hidden mode.
2. Switch off the wifi netword scanning (if applicable)
3. Reduce the screen brightness.
4.While keeping in pocket, take care to ensure that the mobile screen not at all touched or pushed inside pocket even though the screen is locked.
5. Charge th emobile phone for continuous 5 hours and dont charge until fully discharged. Follow this for atleast 5 times.
Then you can see the improvement in batery backup time.
I hope this is helpful to you
Dec 31, 2009 | LG KU990 Viewty
How long to charge battery?
bateries have their own specifications.You can read it on the label.But,most of all it must be charge from 12-15 hrs. on its very first charging ( for a new battery) and later on or for the second time and so on, you may charge it 2 to 4 hrs.,sometimes 8 hrs..Leting you know,a battery can be charge even a short span of time,for example is 30 minutes only.In that 30 minutes try to measure its stored volt using a volt meter or a multi-tester,and the result is laready 12 volts (if your batery is 12 volts.)do you believe that? YES.! because a battery is so easy to store power.But,the problem is that its so easy to drain its stored power.You know why?because the current or amper of the baterry is still weak that the given specification.,.So,for short explanation,the longer time you charge your batery equals the longer time to drain the power.For example: when you charge the batery within 4 hours,thus the batery will be drained after 4 hours.
Oct 31, 2009 | Black & Decker 8 Inch 12 Volt Cordless...
ICOM IC-F11
Bad battery, Buy new one on ebay. Carl
May 17, 2007 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
Cell Phones Logo
37 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
