My Amana washer wont stop filling it will over fill with water and will not switch to wash but if you set it to drain and spin it will drain
If it won't switch to wash, i would be checking the pressure Switch and tube between Switch and tub as well as the water valve v
The fill solenoid is stuck in the open position. Replace it for proper operation. Search Over 2 1 Million Appliance Parts
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it. Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
SOURCE: washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
SOURCE: Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
SOURCE: Washer won't drain or spin out the water
i pulled the motor out od the bottom and pulled a baby sock out of the gear in the balis tank
SOURCE: washer wont drain. fills
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
