Question about Toshiba Satellite U305-S5097 Notebook
I cant find cmos battery where can i find? - Toshiba Satellite U305-S5097 Notebook
    President:
  • 1,623 Answers
Hello heartsaver..The CMOS battery is located inside the notebook on the motherboard...Lots of little screws to remove to get to it...heres a guideline to follow if u wish to attempt it...
1. Remove the battery (side latch release) and hard drive. The only screw that holds it down is marked F-4 on the cover. (look for the panel with the 2" circle, that is the HD)
Use the white pull tab to move it left then upwards. It should move with little effort. Be careful not to loose the screw from the HD panel.
2.Remove all screws annotated F6 from the bottom bezel with a Pt. 2 screwdriver. (from my count there was around 15)
Depending on the screwdriver, there are times where you might have to push the screwdriver down a bit to get in contact with the thread. Just be careful not to strip the threading.
3.Remove the "B25" screw located near the heat sink-fan vent. Somewhat carefully take your hand, and lift the bottom bezel up enought to disconnect (about 1-2 inches from surface) the battery with your index and midde finger. Look at they way the battery is run, and seated in the pastic clips..this is IMPORTANT.
With the bottom semi-open, plug in the replacement battery, and re-seat it in underneath the white ribbon cable, and clips on the housing per the original.
4. Replace all screws
5. Re-seat the hard drive, by sliding it in first with the metal tab under the plastic housing, to the left, then puling it to the right. Replace the panel with the one, shorter, F-4 screw. Reseat the battery.
If you wish to test the battery, simply unplug it and remove the battery for 30 minutes. Then power it on with only the A/C adapter. If no CMOS screen appears, you are good to go.
Good luck..i hope this helps..please rate me a fixya.
Posted on Jul 28, 2009
CANT ACCESS BIOS
Remove CMOS battery (Large button battery on the main board). Removing the CMOS battery like the one shown in the picture causes the system to lose all CMOS settings; including the password. To do this, locate and remove the CMOS battery from the motherboard for at least five minutes, then replace the battery and turn the computer back on
Jul 06, 2016 | Computers & Internet
Windows password reset 9.0 download
Remove CMOS battery. Removing the CMOS battery like the one shown in the picture causes the system to lose all CMOS settings; including the password. To do this, locate and remove the CMOS battery from the motherboard for at least five minutes, then replace the battery and turn the computer back on
Cant find cmos battery on gateway dx4320-19 motherboard
Welcome to FixYa
Here is an image of a cmos battery for a motherboard. Hopefully you could use this as a reference
A cmos battery could be located anywhere on the motherboard but they all look alike.
Hope this helps
May 11, 2011 | Gateway DX432019 PC Desktop
My toshiba equium just wont except the main password, cant reboot..cant get into bios
At this time you need to cleat the BIOS password first so that you can get into BIOS. To cleat the BIOS password you need to open your laptop you just remove the battery first. Remove the screw and open the back cover. Locate the CMOS battery, all password are stored in CMOS memory.
Remove the CMOS battery to clear the stored BIOS password, Or you can remove also the CMOS jamper near the CMOS battery and turn on the unit with in 10 second and turn off. Reinsert the jamper. Now the BIOS password are already clear you can get now in BIOS to change some settings. Good luck
Oct 08, 2009 | Computers & Internet
I have a battery dead on the mobo. changed it, now i cant get past the cmos p-word. tried pulling the batt, and jumpers. nothing works.
Make sure power is off and unpluged. Pull the CMOS battery out and get a screw driver. Then touch the two battery tabs where the cmos battery goes for about 1 minute or so. This should reset the cmos.
Aug 05, 2009 | VIA : EPIA-M10000 C3 1GHz...
Where is the cmos battery in a pb easynte laptop
you cannot see the cmos battery if you don't open all covers of laptop its in the main board. some are in the memory cover only.
Jun 28, 2009 | Computers & Internet
Password bloked in my laptop
Unplug AC power. Remove the battery. If there is a CMOS battery (a rarity for laptops now), remove that as well. Press and hold the power button for at least 10 seconds. Replace batteries. Reconnect AC power. Turn on machine. CMOS should be reset to defaults.
Apr 05, 2009 | Acer Computers & Internet
Sony vaio VGN FJ290P password reset sony vaio VGN FJ290P
I have set the password for administrator when i entered the bios set up. you can change its setting but not the configuration unless you've entered the password. you can't change the password with a new one if you cant enter the old password. Next time dont forget your password because laptops has its security even when stolen you cant open its bios set up if its protected by password. CMOS battery is in the mother board. You need a service technician to open your laptop to reset the bios setup battery.
Oct 11, 2008 | Computers & Internet
Problem with ma ibm thickpad
loose the back of yr ibm if u cant find the cmos battery then u might need to disasemble the whole system carefully under the key board i think thats where th cmos battery will be.
Note removing cmos battery in some systems dont clear cmos password u have to do some additional work to remove yr password. for the battery prob try using a diff battery to be sure what ur prob is.
thank u
May 26, 2008 | Computers & Internet
MSI MS-7142 motherboard problem
try cleaning CMOS with cmos jumpers or just remove your battery of motherboard for 10 seconds (previously unplug power from PC.)
Jan 31, 2008 | MSI K8MM-V Motherboard
Toshiba Satellite U305-S5097 Notebook Logo
108 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
