Hotpoint aquarius 1000 deluxe
The washer wont spin but drum still rotates and adgitates during wash cycle
  • 1 more comment
  • Anonymous Mar 13, 2014
    Noisy on spin cycle
  • Anonymous Mar 26, 2014
    Wont do a final spin
  • Anonymous Mar 27, 2014
    drum wont spin
  • 1,294 Answers
Try the "spin only" button to take the water out of your machine. If this does not work, take the pipe from the wall socket and lay it on the floor for the water to spill out. The spin normally does not work when the outlet filter is clogged; if the filter is clean you should then check your pipe coming out from under the tub (plug off the wall first before doing all these things). Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
Plug off the wall, & check your outlet filter first.
Posted on Nov 26, 2007
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
Drum or basket rotates 3/4 turn one direction the pauses 10 seconds then rotates 3/4 turn the other direction during wash cycle. Does the same during spin cycle.
This is normal operation for the machine It is doing this to get detergent and water to all of the loaded cloths and also to balance the load for when it is washing and spinning
Nov 05, 2015 | Maytag MAH21PD Front Load Washer
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Washing machine travels during the spin cycle
Hi - Try to rotate the drum when it is not in use, manually and see if you notice the sound as well. If you do the drum is not balanced and you would need a professional technician to diagnose the bearing and pulley system behind the drum for repairs.
Oct 27, 2012 | Frigidaire ATF6000ES Front Load Washer
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
My washer does not spin or move during wash cycle the moter runs but nothing is moving.
Hi, this motor has faulty windings, causing it to lock up and not rotate the drum/basket. replace this motor asap if possible.
May 29, 2009 | Kenmore Washing Machines
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Washing Machines Logo
414 people viewed this question
Top Washing Machines Experts
