Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Why am I getting a "need to prime" message. I have low water flow when I open the hot water/steam valve to prime the machine as per the user guide.
  • Ernest R
    Ernest R May 11, 2010
    Is the pump running when the valve is open?
  • 1,089 Answers
HI
The problem you have is, there is a restriction in the intake of your flow meter. It usually is a piece of coffee that fell into you water receptacle when you had the water tank off. Then you filled the bean hopper and the chip of coffee fell in the receptacle, and then you replaced your water tank and that let the chip flow to your flow meter and now you have a slight flow of water and you always get the ventilate message.
You need to remove the flow meter (in the back bottom of the machine, attached to the tube that goes to the receptacle) and clean the intake side, and then remember "When you are working on either the beans or water, make sure that the other one is covered".
Posted on Jul 29, 2009
Initially when the unit said need to prime, no water would flow out of the steam unit. After pulling the pump out and cleaning it, not sure what was blocking water the steam unit now has water pressure,...
I fixed the same issue by pushing in the water knob "in" towards the machine. Machine than primes normally as the water flow is restored and it resets itself.
Dec 13, 2010 | Starbucks Saeco Italia Digital Barista...
My Saeco Incanto Sirius machine keeps asking for yet another VENTILATE cycle
This means the water cannot flow through the machine. Normal fix is to prime the machine (turn water dispenser on, fill a cup) or descale the machine. Go through the menu, select descale, enter, then turn the steam knob fully anti-clockwise. You should put the descaling solution in the water tank first.
If you have the auto-descale in the menu then run it. Run the solution through the machine twice. Then rinse well.
Oct 03, 2008 | Saeco Vienna De Luxe Espresso Machine
Tip
Ventilate error -
The following procedure works when you get the ventilate error:
The Ventilate sign can be due to one or more of the following reasons:
Cause 1- Water leaking from the inlet valve below the water tank. The hose from the inlet valve to the pump can be air locked. When using the hand pump, do not thrust its nozzle too deep
Cause 2- Blockage in the passage of water due to clogged passage anywhere between the pump and espresso delivery nozzle.
Cause 3- Pump is not working. Open steam/water outlet knob and hear the pump work. If you do not hear any noise from the pump, this may be the main cause.
Cause 4- Flow meter is faulty. This part is like the water meter for homes. It measures the flow of water and signals the electronic board. The malfunctioning flow meter will not send signals even when water is flowing through it.
Cause 5- Hose is disconnected and water is not flowing in the system.
Cause 6- O-rings at hose connection is leaking, reducing the water flow to be sensed by flow meter.
Cause 7- Boiler gasket is leaking. Reduces flow of water through the system.
Cause 9- Brew unit is blocked, blocking flow of water through the flow meter. This also causes pump to slow down and ultimately stop with muffled sound within 15 seconds.
Cause 10- Brew unit not connecting brew valve, preventing flow of water. Same sign under cause 9.
Cause 11- Steam is leaking. Registers reduced flow of water at the flow meter.
Cause 12- Solenoid valve is blocked or solenoid coil is bad. Same observation as cause 9.
Cause 13- Electronic Control board is bad. Though rare it can happen due to condensed water from leaking steam. When steam is leaking or boiler is leaking, machine should not be used any more to prevent steam shorting the Electronic board.
Some of the above causes can be checked and corrected before seeking technical help. Do not assume anything without physically checking each of the following:
1- Make sure the water tank is full. If the water tank has water level float, make sure the float is in its housing and it floats as water is filled in the tank. If the level float does not rise with the level of water, then replace the float.
2- Water is not leaking from below the tank. The inlet valve is good. If leakage is present, replace the gasket in the water inlet valve.
3- Prime the machine by opening the hot water knob for 20 seconds or pressing the hot water button. Hot water flow shows the boiler is not blocked with minerals and pump is good. The solenoid valve is good.
4- Water & steam flowing normal, check the brew group for blockage. Determine when was the last time brew group was cleaned. Clean the brew group as explained elsewhere on these pages. If the machine has pre-ground function, try making a fake espresso (without coffee). Make regular espresso in other models to make sure that water goes through brew group and espresso is dispensed.
4- If hot water does not flow because the pump is not activated, then pump is bad. Replace pump.
5- Pump starts to work but within few seconds its sound is muffled and finally stop. This indicates there is serious blockage in the water line or the boiler is clogged with mineral deposits. If water is leaking and seen on the counter top, the chances are that water is leaking from hose connections(replace O-rings) or the boiler is leaking from seams (replace boiler).
6- Prime the machine by opening steam outlet for 20 seconds. Steam flow shows that steam boiler / steam outlet is not blocked. If the steam does not flow, then steam boiler or steam passage is blocked. Replace steam boiler or steam valve
7- Check the solenoid valves to make sure that they open & close as the coil is energized. Solenoid valve is located between the pump and boiler. The pump is activated simultaneously as the solenoid valve when espresso selection button is pressed. Some models may have a solenoid valve near the steam valve. In these models, the solenoid valve is activated to allow passage for steam/hot water. If the valve is not functioning, the ventilate sign will appear.
7- Hear the pump work when priming the machine. Louder noise from the pump can be due to
** air-locked water hose, or
** water is not sucked from the tank or the pump is sucking air instead of water or
** the diaphragm inside the pump has lost flexibility and not developing pressure to push water forward
** the hydraulic system is blocked at one or more locations due to mineral sediment. Find the location and cause of the block and correct it.
** Clean the brew unit (see cleaning instructions) and make sure that
a- the ground coffee used is not powdery fine.
b- The dose of coffee grounds is not in excess specification
c- check if there is blockage. Find the cause and remove it.
8- If steam and hot water flow is normal, but the ventilate sign persists, then the flow meter or the electronic control board is bad. Replace flow meter or the control board, as necessary.
Try also the following:
  • Press hot water button once. Message on the screen will not change, this is normal.
  • Open the steam knob and allow the water to flow freely from steam wand into a cup. The screen should now read "Hot water,ventilate", you may need yo empty several cups of water before message changes. In some case it is necessary to refill the machine container without interrupting the operation.
  • As soon as the screen displays "hot water," turn the steam valve off .
  • If the machine warms up again, then problem is fixed.
on Jan 21, 2011 | Saeco Magic Comfort Plus Espresso Machine
Ventilate!....shows in window and machine will not ventilate when knob is opened. it has regularly been de-scaled but we do live in a hard-water area.
Generally you can clear the ventilate error by pressing the button for Hot Water and then opening the steam knob. You should hear the pump run and water should start to flow from the steam wand. If it doesn't, try removing the frother nozzle so just the chrome pipe is showing.
To remove the frother nozzle you slide the outer sleeve off, and then grip the nozzle with one hand while twisting the cap to loosen it. Then it should slide off the metal steam pipe. Or you can check that the tip of the nozzle isn't clogged.
If you have the frother removed and the steam pipe is definitely open and not clogged and you still hear the pump running but no water is coming out, the next step is to prime the pump.
If you still have the squeeze bulb pump that came with the machine, you can use that - or if you don't have it, a turkey baster will work. You want to take the water tank off and set it aside, then pump water into the valve in the center where the tank had been sitting. You choose "Hot Water" and open the steam valve so the pump starts and then pump water into that valve with the Turkey Baster. You should hear the pump catch and start to move the water - when this happens immediately close the steam valve so the pump stops - then replace the water tank (filled with water please) and open the steam valve again and let water run out of the steam wand for several seconds.
That should clear the ventilate message.
Oct 21, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium. Fault suggests ventilation required. Followed manual instructions, nothing happens. Tried rinsing, nothing happens. Tried hot water nothing happens? Have taken out and cleaned all pbvious...
Do you hear the pump working but no water flows?
You should select hot water (the third button from the right) and the display should say "hot water" at the same time it is saying VENTILATE --- open the steam valve all the way and the pump should start and you should see water from the steam wand.
If you don't hear the pump at all, then that is a different problem.
If you do hear the pump but still don't get any water with the steam valve open, then you need to prime the pump by using a turkey baster or the accordian pump that came with the Titanium to pump water into the valve where water from the tank goes. Remove the tank and use the turkey baster to pump water into that valve while the pump is running and the steam valve is open all the way with HOT WATER selected. the second water starts to come out the steam valve you want to stop the pump (turn the power off or turn the steam knob shut) and put the water tank back on and make sure there is plenty of water in the tank - then start the pump again by opening the steam valve all the way and let it pump water out the steam wand for a few minutes.
Oct 05, 2010 | Gaggia Titanium Espresso Machine
Hi, I a problem with my Saeco s-class incanto classic coffee machine. The two coffee cup lights are flashing green the water light is flashing red. I prime by turning the steam valve and hardly any water...
Try this, when you run the hot water cycle to prime machine and it stops putting out water push in on the knob if that works then replace the tap rod assembly or the whole steam valve assembly.
Aug 29, 2010 | Saeco Incanto Classic Espresso Machine
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
Small coffee and coffee buttons flashing, hot water button on solid, water tank and priming butten on solid. I can open steam knob and let cold water run all day, but that's all that happens. What's wrong?
HI
Its your flow meter. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed. Coffee grounds will get into the intake and restrict the flow meter. If you get a restriction in the water intake (below the water tank, on the machine) the pump may run and water comes out, but the flow meter does not create the jet of water to spin the turbine wheel to send impulses to the computer. You get the ventilate message.
You need to take the flow meter apart and clean it or replace it.
Nov 18, 2009 | Saeco Incanto Classic Espresso Machine
Brand new Saeco Villa machine won't prime
Press hot water button then open valve, then push the valve knob in if that works take it back and tell them that the valve is damaged.
Aug 29, 2009 | Saeco Vienna SuperAutomatica Coffee...
Via Veneto will not prime
Yes, unfortunately the Via Veneto is a difficult machine to prime, however, I have a simple way to prime the pump if you run into this problem. Simply remove the water tank, fill a clean turkey baster with water, open the steam valve fully then mate the baster tip with the water tank flow valve on the espresso machine. Wrap a towel or paper towel around the flow valve/baster tip then inject the water (agressively, but not forcefully). It's works for me every time.
Sep 18, 2008 | Saeco VIA Veneto Espresso & Coffee Maker
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
380 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
