Question about Roland Vs2400CD Digital Workstation W/CD Recorder System
I see input level i place tracks in record but when I play back I dont hear anything or see any levels on the tracks. Please help
  • skylarjaymz Jul 28, 2009
    Unit was defective finally spoke to some one at Roland.
    Thanks anyways
  • 5,807 Answers
since you are seeing input level, try to record again with the level just reaching the maximum.
and where do you place the recorded output?
there is a possibility that the recorded signal passed through the recorder , but the problem is where did it go?
the recorded output is checked on your level tracks, what format have you tried recording? i mean is it mp3 or mp4 or wave?
some audio have copy rights too, especially the CD audio, cant just be recorded digitally, some do on analog audio, but on mp3, wave no
problem with the recording. try recording mp3 as sound track, if it can record mp3, need to convert your audio files that you want to record in mp3. you need an audio converter.
this is just a suggestion, if you are still having problem, please indicate the make and model of your recorder, include the type of audio you are recording and the software you are using.
hope i have helped you, thanks for using Fixya!
Posted on Jul 29, 2009
  • Rommel Cana
    Rommel Cana Aug 11, 2009
    hi,
    if you have a computer , you can use your computer in lieu of the recording unit in your mixer,
    still you can use your mixer as a playback mixer not a recording mixer, since Roland said it was a bad unit.
  • Roland Master
  • 19,396 Answers
Ensure that the track button is solid red when recording.
Ensure that you are recording the right input channels on a track. see pages 130 to 165 on the manual.
Before you can record signals received by the VS-2400CD’s coaxial or optical digital IN
acks, you have to enable digital recording .
To enable digital recording:
1. Hold down SHIFT and press F4•UTILITY.
2. Press PAGE until “GLOBAL” appears above F2.
3. Press F2 (GLOBAL).
4. highlight the CD DIGITAL REC parameter if necessary.
5. Turn the Time/Value dial to select On.
The “Concerning Copyright” statement appears as a reminder of the laws
governing the digital copying of copyrighted materials. It also presents Roland’s
position on the SCMS digital recording copy-protection protocol.
6. After reading the statement, press ENTER/YES, or press EXIT/NO to suspend
activation of digital recording.
If you pressed ENTER/YES in Step 6, the VS-2400CD licensing agreement appears.
7. If you agree to the displayed terms, press ENTER/YES. If not, press EXIT/NO to
leave digital recording disabled.
Also read carefully Routing Input Signals to Input Channels at page 130 on user manual.
Good luck.
G.
Posted on Jul 28, 2009
The input levels of the left and right microphones are highly inequal, what can I do?
perhaps the left speaker is damaged
what i would do is load a known mp3 too the sdcard
and play it back on your unit
if its aok level wise
then the left mic has an issue
try an external input too the left mic
if it again records bad there is an issue with the input amp and alc circuit
if it records ok chances are the left electret mic has failed and will need replaced out usually these small mics have an amp built in then this output goes at line level to the input switched between line level in mic in or internal mic in as a mix....
Jan 10, 2015 | Yamaha POCKETRAK C24 POCKET RECORDER
With adobe audition 1.5 how do i get my voice to play back through edit view? Ive really been up all night trying to figure this problem out someone please explain step y step
First, be sure you see the audio track on "edit view". It shows the peak of the recording level. If it is a straight line, you have not recorded your voice. If the recording is there, you have to be sure your computer audio is set to play back through the speakers. If the recording is not there you have to set the computer to record from your input, either line or mic input. Set the level to the max. When you record you can see the input level on the two bars at the bottom of the screen. Double click on them to see the input level before you start recording. You want the level to be near "zero", at the far right. If the level is above "0" the peak indicators will turn red. You don't want red lights. Set the input level just below the red peak. Click on the red record button at the panel on the lower left of the screen. When you click the record button you may see a pop up that want you to set the recording parameters of the file. You have to make these selections before you can record. Once that is done, the record button will show the record position and audio track scroll across the screen. You will also see the level bars respond to the input. When finished recording click the stop button. You should then be able to play back the recording.
There are many adjustment and changes you can make to recorded files. The Adobe help files are very good explaining the features of the software. It is a very powerful audio system. Good luck and have fun with voice and music tracks.
Thanks for using FixYa.
Gaker
Jun 15, 2011 | Computers & Internet
Hallo i have cubase sx3 I can get my backing music onto track one via importing it from docs - no problem - how do i increase the volume on record as the tracks from vocals dont come out loud at all ,...
You must adjust the record level from the input device - i.e. mixer or soundcard. There is no input level control within Cubase. It is often the case, however that the problem lies with the backing track being too loud.
May 28, 2011 | Steinberg Cubase SX3 (502010600) for PC,...
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Having problems recording and playing back tascam dc-02 cf
I'm assuming you are plugging the left and right outputs from the karaoke machine into input A and B of the Tascam to record the stereo output of the Karioke. The Tascam works with mono only (you recreate the stereo mix at mixdown or when bouncing mono tracks together with the panning set). Therefore you should be assigning inputs A and B separately. You could press assign A and then the record button above track 1 and then press assign B and the record button above track 2. Then arm tracks 1 and 2 (by pressing record above each). When you then press play and record together you'll record input A onto track 1 and input B onto track 2.
Hope this helps.
bd.
Mar 25, 2009 | Tascam 2488 Portastudio Multitrack...
Machine appears to record per instruction manual but will not play anything back and the instruction manual includes NOTHING on playback except to hit STOP when we're through recording, back up to the...
it appears to be recording but is it really?
when you are recording there are two levels you should see moving up and down on the screen. the input volume and the recording volume per track. dont forget to arm the track. tascam has a silly way to arm the track on some of there unit. its combination of buttons. something like hold down the record button and press the track arm button then release both. when youre ready to record press play.
Feb 22, 2009 | Tascam DP01 All-In-One Recording Package...
Poor Recording Level on the Tascam DP-02CF
When I record on DP-02/CF Tascam I can't get the music to play back. Do I have to do something other than rewind to be able to hear it? Albert S.
Feb 08, 2009 | Tascam 2488 Portastudio Multitrack...
Record, playback problem
Hi Nick,
The fuzz/white noise is a little confusing and it seems to be saying that you are recording something vs trying to record incorrectly and getting nothing at all. Anyway, despite that, I would try going over your recording steps first.
First off make sure your Hi-Z input is not set to the Hi-Z or guitar setting. It is possible your that MicroKorg is overloading the input and distorting. You should however have heard that in the headphones too, so I'm not so sure that's the problem. The next thing to check is to make sure your input is assigned to the track you expect to be recording on. (Press the input's button to check this. The select/record button over the track should flash).
Next make sure your track is armed for recording before you press 'play+record' (Record button above the track should light steady when recording).
Hope this helps.
bd.
Nov 21, 2008 | Tascam DP01 All-In-One Recording Package...
Connect yamaha keyboard to tascam 2488 MKII
There are 8 inputs on the back. 4 of them support XLR type microphone connections, but also double as 1/4 inch and the remaining four are just 1/4 inch. These are all line level inputs and you can use any of them for a keyboard hookup. Typically you might leave the XLR inputs (A thru D) available for mics and take the next two (E and F) to use from your keyboards L and R outputs. Then just assign those inputs to two adjacent channels (tracks) or one of the stereo pairs, turn up the input levels for those inputs and the faders for those tracks and you'll be able to hear the keyboard playing through the 2488 (or whatever monitors/or stereo you have hooked up to it for monitoring). To record the keyboard simply arm whatever tracks you have those inputs assigned to for recording and record away.
bd.
Oct 30, 2008 | Tascam 2488 Portastudio Multitrack...
Problems recording with Sony Acid mucic studio 7!
This probably has to do with the levels you have set for the sound card - take a look at your mix levels AND the volume input level 0 this is not the same control as output
Sep 30, 2008 | Sony ACID Loops - Ugly Remnants: Volume...
Roland Vs2400CD Digital Workstation W/CD Recorder System Logo
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Vito Vacirca Jr.
Greg Cann
Greg Cann
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
