Question about Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1027 network connection problem with vista x86
When i plug-in the network cable from PC to Ricoh Aficio 1027, the PC show up network disconnect ( vista OS), if (XP OS) will work properly. i also try unplug network cable from Ricoh Aficio 1027 and plug in to DSL mordem, the PC show up network connection. i already try many time but the problem still same...
    New Friend:
  • 22 Answers
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Posted on Aug 09, 2009
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Why does Ricoh aficio 4001 pcl6 appear offline?
Check the connection to the machine. Otherwise the IP changed on the machine or the network you're on IP changed.
Jun 12, 2014 | Ricoh Aficio 1027 All-In-One Laser Printer
Aficio 1027 only print first couple of pages
Could be several things. I would start by eliminating the easiest things. Try another cable, decrease dpi settings (less memory usage), try a USB cable to see if theres a difference if a port is available. Update the print driver from Ricoh website.
Nov 20, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
How do you clean/service a Ricoh Aficio 1027?
you had to have the ricoh 1027 manual & can be download from any technical ricoh forum esp from copytech.net if you lucky, you can download for free
Sep 12, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
Driver af1027 for scanner microsoft x764
Good afternoon from Chicago, shiva262,
I'm not sure from your post above, but it appears that you are looking for a driver for your Ricoh Aficio 1027 All-In-One Laser Printer. If that is in fact the case, try the following steps to resolve your problem:
1. If your Ricoh Aficio 1027 All-In-One Laser Printer is connected to a Windows-based PC, use Windows Update to try and locate, dwnload and install the correct driver software.
2. Navigate to the following links and follow the instructions:
http://www.ricoh-usa.com/downloads/local/manuals/multifunction_bw/aficio1027.pdf
http://www.ricoh-usa.com/downloads/popup/popup_manuals_drivers_download.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x1022_27/x1022_27en.htm
I hope these are helpful in solving your problem. Good luck!
Regards,
Enolram
Mar 01, 2011 | Ricoh Aficio 1027 All-In-One Laser Printer
How to convert ricoh aficio 1027 from german to english?
User manuals are available in pdf from ricoh-usa.com
Nov 25, 2009 | Ricoh Aficio 1035 Copier
How do I connect a Ricoh Aficio 350 directly to personal computer
I believe the copier only has a tcp/ip port for connection, so you will still need to run it through a router, or if the PC is not on the internet, you can connect the machine directly to the ethernet port on your pc using a 'crossover' cable
You will need to download the Vista driver from Ricoh Here:
|http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x35_45/x35_45en.htm
Mar 23, 2009 | Ricoh Aficio 350e Printer
Ricoh Aficio 1027 All-In-One Laser Printer Logo
999 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
