Question about Sprint Hitachi P300 Cellular Phone
I have a RAS-3HG7E and the indoor unit is a RCI-3HG5E. My problem is that a cannot get the louvers to work.
Fujitsu a/c outdoor model number AOTG12LVC indoor unit economy light flashing continuously, operation light single flash, timer light single flash this sequence repeats
Serial communication error. This means that the indoor unit is not communicating with the outdoor unit usually because the outdoor unit is faulty. You can check the indoor unit by switching it to 'fan' mode and seeing if all functions work normally (fan speed, louvers move as directed). If it responds normally, then it's probably ok so you can turn your attention to the outdoor unit. A common problem with the outdoor controllers is that they are susceptible to bugs, geckos, etc. shorting them out which will mean replacement of the board.
Mar 05, 2017 | Fujitsu Heating & Cooling
I have a "Hitachi split type air conditioner model RAS- 3098U", and its started leaking today from the right side. I didn't install it and I can't figure out how to remove the front cover to l
water is coming from evaporator drain pan most likely. lots of humidity right now and 1st thing your ac is going to do is remove this from air. most likely cause would be condensation line clogged or if you have condensate pump, then it also could be cause. to remove cover usually you have to remove air filters look for any screws and possibly front louvers pull down. this usually does not give you access to drain pan. unit usually needs to be removed from wall plate and this might involve refrigerant lines being removed, and for that my friend you defiantly want a qualified professional.
Aug 13, 2012 | Hitachi RAS-09UH Air Conditioner
Hitachi RAS-09UH Air Conditioner won't turn on
If you can access the pcb inside, check the mini glass fuse
May 18, 2012 | Hitachi RAS-09UH Air Conditioner
Hi, I have Hitachi model: RAS 63CHA4/RAC 63CHA4 The indoor unit looks working for the fan function, but not for the other function. The fan on the outdoor unit looks not working. What is the problem?
Is your compressor is working? If so, check motor to rotate manually. If hard to remove, replace bearings or motor. If easy to rotate, replace capacitor.
If your total out door is not working, check for power in out door unit. If not communication error between indoor and out door, provided you keep in right setting. If so, replace your indoor PCB.Helpful?
Jan 15, 2011 | Hitachi Heating & Cooling
Red blinking and ac not working
If the power "flickers" and unit fails but will restart once the breaker is reset, this sounds absolutley normal. It is a safety device that keeps the unit from burning up things due to improper power being supplied. As long as resetting puts it back into service with no issues, don't worry about it.
May 12, 2010 | Hitachi RAS-09UH Air Conditioner
I hve purchased panasonic split a.c. b4 1 month only, mi remote senson is not working properly, i mean when i push mi remote button, its effect does not come in mi indoor unit sensor.
Ok, there are a few things to check.
1. Batteries on the remote.
2. Reset remote - switch sometimes in battery compartment and sometimes behind cover, need to press with sharp nib or pen.
3. Check on indoor unit that remote has been selected on the manual/auto switch, located under the cover on right hand side.
4. Remove indoor unit cover complete, (three screws behind the louvers and one on the electrical cover). Change the remote sensor board.
Mar 10, 2009 | Panasonic Heating & Cooling
Hitachi RAS-25CHA will not work after power supply -brown outage.
Is the unit responding to remote instruction at all? It does sound like your board is gone. This is usually a capacitor (blue or green and round flat disc) on the pc board, and possibly one of the diodes (small black cylindrical shape with a white line on one side) Often it is the compressor drive relay (rectangular black box) on pc board. If however you have managed to find a replacement board. The plastic heads holding the pc board are released by using a small long nose pliers and pinching the bit sticking through the board. The rest is simply a matter of changing one wire at a time from old board to new board. Or a good method is just to take a snapshot with a camera to refer to regarding the wire positions.
Jan 30, 2009 | Heating & Cooling
Heya,
I am an ex warrenty agent for Hitachi in Western Australia and I will be able to take you through some tests if you want. But from the sounds of it I think that you will be up for a new indoor PCB as these are the most common things to go when there are power failures. If you would like me to go through it with you let me know. But first where abouts are you in Australia?
Jan 08, 2009 | Hitachi RAS-09UH Air Conditioner
Hitachi ras-5h gse
first: The compressor is deffective
second: Fan capacitor is deffective
3rd: Running capacitor is deffective
Sep 05, 2008 | Hitachi RAS-09UH Air Conditioner
Sprint Hitachi P300 Cellular Phone Logo
77 people viewed this question
Top Sprint Cell Phones Experts
Vernon Taylor
rgnestle
Level 1 Expert
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
