Question about Philips 32PW6506 32" TV
Philips 21rf vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking.
please help.
  • 188 Answers
Check option code's.
Posted on Jul 29, 2009
SOURCE:
How to stop blinking philips 21rf vardaan. I can't
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Aug 30, 2014 | Televison & Video
How to enter in server mode in 21rf vardaan crt tv?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
You should have its original remote control to enter the service mode. No universal remote control will go.
Aug 16, 2014 | Televison & Video
Philips 21rf vardaan lot fault
And when you hit it, it sometimes works?
Did you check the solder close to and on the HT transformer?
Please if you are not an electronic engineer, don't open the television, because voltages up to 25.000 volts are there. That can kill you.
Apr 13, 2014 | Philips Televison & Video
Sound problem
when you mail me,i have an service manual for you
[email protected]
Apr 02, 2010 | Philips 20DV6942 20 in. TV/DVD Combo
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Remote code of 21pt2216/94 philips
Yes it worked for me by doing blw :
Press : 062596 & menu button to open service menu.
Then change blw values on option tab :
op1 : 128op2 : 215op3 : 065op4 : 000op5 : 192op6 : 129op7 : 112
then press menu button & power button on remote & plug-out the main cable from power socket for 10 seconds.
Then switch on the unit for result...............
Jul 22, 2009 | Televison & Video
Problem of Audio in Philips TV, Model - 21RF VardanSL
check option bites find it on crt or back cover to enter serv mode coll following comands
062596 menu or display the data will appear select options and set by vol and ch keys
Jul 10, 2009 | Philips 32PW6506 32" TV
Philips 21RF vardaan there is no sound but everything works fine
just open the service manual & change the option to 1-128 ,2- 215 , 3- 065 , 4- 000 , 5- 192 , 6- 129 , 7- 112
By-Rajan
Jul 01, 2009 | Philips 32PW6506 32" TV
buy a remote for rs 100 . select the AV button on the remote .
May 27, 2009 | Philips 32PW6506 32" TV
Philips 32PW6506 32" TV Logo
788 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
