Question about Garden
BR550 Blower No Compression
My BR550 Stihl blower has lost most of its compression, I think the rings are bad. I have been trying to take it apart to investigate,but I CANNOT get the blower wheel off. I've tried an impact, heating, and plain manual force, no luck. Has anyone dealt with this before? Am I missing something?
    Sergeant:
    Champion:
  • 246 Answers
You can rent and use a wheel puller providing that your blower is strong enough not to bend, crack or break under the stress. OR...have a friend help by them or you holding the whole unit up by the blower fan itself and then your friend or you can hit on the blower shaft with a "dead blow" (heavy rubber hammer) type hammer so as to not damage the end of the shaft. If you do not have this type of hammer use a sturdy block of wood against the shaft and hit on the wood with a regular hammer. Blower fan should then pop off. For renting a wheel puller...look in the yellow pages of your phone book under Eguipment Rental or Rental stores.
Posted on Jul 28, 2009
Where is the serial number located on a stihl leaf blower BR550
When the paper bar code sticker is worn off, you can remove the engine shrouding (orange) and it will be located on top fin of the cylinder just before the spark plug hole.
Sep 30, 2016 | Stihl Garden
Timming
take out the spark plug and try turning it over
sounds like too much oil inside it
can cause compression issues
drain clean the oil
you can tell lots with no plug in
could be anything in the transmission to the trimming head
perhaps the clutch is seized up
Apr 22, 2014 | Stihl Br500 Br550 Br600 Flywheel...
Gas cap leaks
the seal is missing youve dropped it in a garden somewhere
you need a new one
try ebay
but i will tell you stihl is VERY good at service parts
and very helpfull
http://www.ebay.co.uk/itm/PETROL-FUEL-TANK-CAP-FITS-STIHL-BR500-BR550-BR600-BLOWER-/141346840553?pt=UK_Home_Garden_GardenPowerTools_CA&hash=item20e8ed9fe9
Feb 19, 2014 | Stihl Br500 Br550 Br600 Back Pack Blower...
Br500 wont start
fuel filter inside the tank and inline
bad start stop switch
bad carbiration
bad spark plug {burned}
bad ht cable
bad magnito coil
take your pick and rull them out one by one
Feb 08, 2014 | Stihl Br550 Br500 Backpack Blower Fan...
Backpack blower
the return spring is shiered up
you need to replace the rip cord cassette or change out the spring
i would ask around the local service guys if they have a spare return spring also the two 'pawls' could be badly worn and need replaced
Jan 28, 2014 | Stihl Br500 Br550 & Br600 Blower Air...
Br550 shuts off after about 20 min. run time, Won't re-start.
fuel tank vent
bad inline fuel filter
leefs inside the tank flush it out
bad plug replace it
bad air filter replace it
bad pickup ignition coil
oil level too high or low take it all out and measure what you put back by the user manual from the stihl site {use google to find it}
Nov 19, 2013 | Stihl Br500 Br550 Br600 Back Pack Blower...
What is the compression on a poulan bvm200FE blower
It has lost compression, I just repaired two that were doing the same thing, Installed a new piston ring in both and they fired up and ran great on the second pull. Also check to be sure the bolts haven't backed out that hold the cylinder jug on to the block, this will cause it to lose compression and not start or run either. A new ring costs $2.00 and can be installed in less than an hour.
Sep 08, 2012 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I too have only had the blower for a couple of years and it stopped while it was running and made a different noise before stopping. I pulled the plug and I can feel compression but there is little or no...
Pretty sure it has seized at some time and has now scuffed the rings into the piston, it will have to come apart to see how bad it is.
Jul 25, 2012 | Garden
Garden Logo
515 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
