Question about LG KC910 Renoir Cell Phone
Same problem here
i have the same problem. Did you already find a solution? Please let me know.
Tony
I have already connected my scanner to the laptop. How will I know if it has been recognised please
install the drivers before you connect it if yo have the software for it.
Tony
Jul 14, 2014 | Office Equipment & Supplies
How to set uk maps on mediatek gps sat nav
Hi Tony
I've been having the same problem, did you find a solution if you did tell e please!! thank you Janet
Dec 02, 2012 | GPS
Hi I have the netgear wiii dongle but no disk, canyou advise please so that I can install.cheers Tony
This is the link for 2.0 version. Hope it helps. http://kb.netgear.com/app/products/model/a_id/2559 After you get there you DO NOT have to register! Just indicate that you have already registered this product and when it asks for email indicate no thanks.
Jan 12, 2011 | NetGear : WG111 54 Mbps Wireless USB 2.0...
My windows 7 is already activated,but my unit has a problem and need to format.can i use my cd key again after formating?
You can use your software three times. After that you will have to call in and get a confirmation number from Microsoft.
Jan 12, 2011 | Microsoft Windows Vista Home Basic for PC
Hi I'm Tony from the Philippines and I have a Compaq presario f756nr notebook pc (to be exact), i want to reformat my laptop and the problem i am facing now is that when i try to use my cd/dvd rom drive to...
Hi Tony,
Thanks for the details you have mentioned. The steps you have taken are correct and if the System/ hardware is ok, it should boot from CD Drive. Whenever i have faced such an issue, i always started afresh to check each hardware (CD, DVD, ROM, Hard Disk, Cables, Connections etc) and most of the times the issue was optical drive or CD/DVDs.
So, I recommend that make sure that the CD/DVD ROM is functioning properly. When the system is set to boot from CD/DVD, it must try to read CD/DVD after power on. It is indicated by spinning of the optical drive and blinking CD ROM LED. If there is a bootable CD in the drive, it should boot. You may try to boot the system through DOS bootable CD. Also, if you still have the OS on your system, you may check the CD ROM through windows.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 09, 2010 | HP Compaq Presario F756NR Notebook
Tony hawk helmet cam/software
The software is not available for free download. However, you can skip that by following method :-
Ok so all you have to do is open the battery door so it wont turn on and then hold the camera record button on the top until I say so. Plug it into your comp and then wait. it should say found mass storage device. Then you will see it under my computer. You can just drag and drp copy and paste the vids and play them with windows media player. (you can let go of the botten when windos detects it.)
Any further help, let me know.
Thanks for using "Fixya".
Jun 04, 2009 | Digital Blue Tony Hawk HelmetCam Camcorder
LG Shine CU720 LCD replacement
hi there,
your so lucky i got this tutorial video for you...
click HERE TO WATCH & KNOW HOW...
PLEASE RATE MY SOLUTION, WILL YAH..?
`micro
Jun 22, 2008 | Cell Phones
Hi Def from dvd player
Tony, Let me ask you a silly ? as Im sure you can answer your own ?. Is your TV Hi def?? NO?? Ok Is your DVD player HI def campadable? Yes. Does your DVD player have RCA outputs for video or s video Output?? Yes. Ok Tony if your TVs not HI def how do you expect to get HI def out of it??? Use rca outputs as it is compadable. if the DVD player has no s video or RCA jacks and I've not seen one yet that didnt then your going to have to get one that does. Good Luck
Jul 30, 2006 | Hitachi 43UWX10B 43" Rear Projection...
LG KC910 Renoir Cell Phone Logo
110 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
