Question about Sony KV-32S45 32" TV
No power Up , No Sound , No picture
Model Sony KV-32S45
  • Donpatel Dec 09, 2007
    No comments
  • pream persaud Feb 15, 2008
    i have a problem power supply ther was no 5 volt stb i change R 640 and the 5 volt come on but the tv will not come on i will like to know if the au+ the 9 volt and B+ have to be there on cn641 when i plug tv cord in power
    Genius:
  • 1,694 Answers
Requires careful, meticulous soldering of horiz drive circuit +
rebuild power supply.....requires four parts......Horiz out xistor,
two converter xistors and one resistor....would you like part list?
Posted on Dec 06, 2007
3 Suggested Answers
  • 668 Answers
SOURCE: Sony KV-32S45 turns on at first, than blinks out, still sound
I would look for intermitent solder connections on the small horizonal driver transformer as well as other HV Componets.(HV Transformer etc.) Also solder up the Vetical output IC. These have been common causes of failures. I would not use the set until these have been checked and soldered. If you don't, a massive failure of the hoizonal circuit and powersupply will occur.
Hope this helps,
Skyassoc
Posted on Jun 18, 2009
  • 4 Answers
SOURCE: No power Up , No Sound , No picture
Im sorry tom have to inform you that a red light blinking is an indication that the main power supply is good BUT the sweep supply has a problem .. Most likly the high voltage transformer as well as the horizontal transistor is bad. if you have no solid state repair experience, you will not be able to fix this set on your own as we techs do gfo to school to learn the circuits in these sets and there are safety issues you have to know and equipment you have to have. sorry my freind but you going to need to call or take the set top a trained tech to trouble shoot as you cannot look at the board and see a problem. you have to troubleshoot the board and test the circuitry.
Posted on Sep 11, 2008
I have a Sony Trintron also - similar model to the
looks like a horiz.output transistor is shorted.check it...
Jul 08, 2009 | Sony KV-32S45 32" TV
Hope this helps,
Skyassoc
Jun 18, 2009 | Sony KV-32S45 32" TV
Sony tv kv-32s45, standby light flashs continuously. diag code say "no reply from jungle IC301. Is this a board or circuit and where is it located? Is it on the power board?
The set needs service, count the no of times the RED LED blinks & contact the serv centre as it indicates the part problem.
Jun 12, 2009 | Sony KV-32S45 32" TV
TV does not power-up Red flashing light
andrews electronics.
(800) 289-0301 fax
800) 274-4666 phone
give them your model number and ask price qwote on replacment power suply.
the unit sounds repairable and the board is a simple swap.
daniel.
Jan 11, 2009 | Sony KV-32S45 32" TV
I have a Sony Trinitron Color TV that was manufactured in March 1999. The Model Number is: KV-32S45. The serial number is 8118319. My TV was accidentally plugged into a 220 outlet with an inadequate...
yes the power supply inside the unit is now gone.
it needs a rebuild.
or replacment, you can call a company named andrews electronics, give them your model number and ask them cost of power supply board..
hope this helps you.
Sony KV-32S45 32" TV no power
If the power plug is fused (like in UK) check the fuse inside the plug.
Test a different power socket.
If there is no power at all, and the power cord is good, then it is a faulty power suupply board. Probably a capacitor on power board had blown.
The board must be tested and repaired by a technician.
Jan 06, 2009 | Sony KV-32S45 32" TV
Hi just been given a sony 50" tv but is not working how do i tell what model it is
Using a good light source, check for model information molded into the plastic rear housing. You may have to illuminate at an angle to see it clearly. Often, it is near the power cord entrance.
Dec 09, 2008 | Sony KV-32S45 32" TV
Vertical fold over
if the set has a previous vertical line problem and a white horizental line only comes in the cross of the screen and you turned the tv on for a time while the problem is solved that mean you have make a burnt line to the screen , but if you are the tv owner and nothing of that happens so you have a problem in faulty dried capaciter in the vertical live part search for 33uf 160 v or 22u 160 v and alter regards please don't forget to rate thx
May 01, 2007 | Sony KV-32S45 32" TV
Sony KV-32S45 32" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
