I have P4 Intel 915GLVG Mother having 4 Ram Slots and i want to use DDR2 Ram Instead of DDR1 can i change my Ram from DDR1 to DDR2 Does it supports
    Sergeant:
  • 173 Answers
No it is not possible you must need new motherbord which supports DDR2 if you want to change.
Posted on Jul 28, 2009
What is the max size of ddr400 memory you can fit into ddr1 & ddr2 dimm slots on a p4vm8 mother board
1) Total maximum amount for motherboard is 2GB.
2) There are 2 Ram Memory slots.
3) Maximum amount for EACH ram memory slot is 1GB.
Either DDR Sdram at 266MegaHertz, or 333MHz, or 400MHz.
PC2100, PC2700, and PC3200, respectively.
http://www.asrock.com/mb/VIA/P4VM8/
There is no DDR1 and DDR2 slots, in a manner of speaking.
May be marked on your motherboard that way, but stating it that way on a computer product support website = No.
You're going to make someone think, you don't know what you are talking about.
They may think you are referring to DDR Sdram, and DDR2 Sdram, and they know the motherboard only uses DDR Sdram ram memory.
Suggest state Slot 1 and Slot 2; or DIMM 1 and DIMM 2.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 18, 2013 | VIA ASRock P4VM8 P4(S478)/...
I have pc p4 3.06 intel processor and i hav now DDR1 RAM in my pc can i use ddr2 ram by removing ddr1 ram will my motherboard support ddr2 ram
Sorry but you cannot interchange ddr1 for ddr2. They are different kinds of RAM, and your chipset (865GV) can only accept ddr1. If you want to use ddr2, or even ddr3 then upgrade to a newer motherboard.
Mar 09, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Will ibm rev1.6 motherboard will support DDR2 RAM ??????
Check the RAM slots -- in the "channel", there are small vertical "blocks", so that only *ONE* type of RAM (SDRAM, DDR1, DDR2, DDR3) will match-up the "slots" amidst the gold pins on the RAM.
Given that it's a ThinkCentre/NetVista motherboard at 400 Mhz:
http://www.shopping.com/xPO-IBM-SYSTEM-BOARD-W-O-POV-02R4087
with a Pentium 4 CPU, it's very-likely that it _only_ supports DDR1 RAM -- it's simply too old to support DDR2.
Dec 05, 2009 | IBM (02R4087) Motherboard
I want to upgrade my ram for my pc...atmost to how much i can upgrade and in each slot individually how much capacity of ram it supports ...my motherboard is 915glvg
i would like to inform you that *********** board supports upto 4 gb ram and 2 gb in 2 slots will be the best combination but depends on the OS you are using if its 32 bit XP or Vista it wont accept more than 3 gb so if you wish to use your system in full throttle mode upgrade you r OS to 64 bit XP or Vista and enjoy all 4gb standards that you actually wish to but even 3 gb is like playing with wild fire that will be really too fast processing speed and thrilling performance that you expect.
thanks and regards
kindly rate this solution
Oct 28, 2009 | Intel D915GLVG Motherboard
Can i use ddr2 ram in my pc inplace od ddr1 i cn purchase pc 07?
Hey there, Check for the slots given on your motherboard, whether all the slots are same; However a motherboard can support only one type of module either DDR1 or DDR2. your motherboard has only DDR1 slots. You cannot upgrade DDR1 to DDR2 cause the Memory Module or notches are different than eachother. Gimme Acknowladgement by rating me. Thanx - Romy Decostza
Jun 09, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
D865GSA intel mother board supports DDR1 or DDR2 ram
Straight from intels web site...
Two 184-pin DDR SDRAM Dual Inline Memory Module (DIMM) sockets Support for DDR 400, DDR 333, and DDR 266 Support for up to 2GB of system memory
Mar 09, 2009 | Intel D865GSA (BOXD865GSAL) Motherboard
Need to buy a new Mother Board?need some help
Now a days every motherboard is come with PCI-Express Slot and this mothrboard can also handle more than 3.0Ghz CPU and it support DDR2 RAM which is faster than DDR1 RAM.
High FSB and high storage of DDR2 RAM will increase your computer performace.
DDR2 RAM FSB is depend on your motherboard choice. Because your motherboard should be able to support your RAM FSB rate.
Mar 05, 2009 | Intel Motherboard
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
Few questions about RAM memory?
Solution:
i)  LOW DENSITY modules have 100% compatiility with ALL systems and ALL chipsets.
    HIGH DENSITY modules only have 10% compatibility
    here compatablity means LOW DENSITY RAM are accepted by all system(100%)  or any make           system.. HIGH DENSITY RAM are accepted by 10% by only some system or computers...
ii) in order to check system performance or amount of Computer RAM usage press the ctrl+alt+del
   simultaneously a new window(window task manager) will appear showing:
    CPU usage: showing the amount of CPU or processor utilized at that particular time.
    PF usage: showing the amount of RAM memory utilized at that particular time.
    Physical Memory: showing Total RAM Memory, Available Ram memory....
iii) baiscally they are two types of RAM they are:
    DDR1:which is older one supported by older system  or older mother boards which is costlier
    DDR2: which is latest one supported by all new system or new mother boards which is less                         costlier
    DDR: double data rated ram......which will send data at a double rate compared to SD RAM
iii) here color doesnt matter, these slots either support DDR1 or DDR2 but not both at a time
    DDR1 has 184 pins or gold plated pinssss... on the edge of the RAM
    DDR2 has 240 pins
    so difference doesnot allow DDR2 to placed in DDR1 motherboards or vice versa...
iv) it does have anything to do with no of chips on the RAM but they only differ whether it is DDR1 OR DDR 2(DDR2 are much faster than DDR1)
NOTE: whatever may the the RAM, each RAM has FSB(called Frequency...) which determines the frequency of rate at which data is tranferred from RAM to processor(CPU)  usually in MHZ such as FSB 300, 400, 200 , 333...................
more the FSB the faster data is transferred to the processor(CPU)
dont worry even RAM with less FSB's work well with the processor....having 1 GB RAM or 2 GB RAM is engouh, it only matters with the speed of CPU ... but not RAM......
Sep 24, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Computers & Internet Logo
322 people viewed this question
David Payne
David Payne
