Code13 unit was working shut it off to clean filter when restarted the code came on
    President:
  • 986 Answers
Did you unhook any wires when you removed the filter?
Posted on Jul 28, 2009
Shuts down and gives me failure E 1 on the card and will not start
E1 = The air filters need cleaning (after 720 Hours use)
It will shut down until you clean the filters & reset the E1 alarm code.
To do this you need to:
Pull the Air Con appliance lead out of the power outlet in the wall.
Remove & Clean the air filters & then put the cleaned filters back in machine
Before plugging back in you Push & Hold the Power button on the Unit
THEN while holding the power button you PLUG the lead back into the wall.
Keep Holding the power button until you hear the unit emit a beep (hold for approx 5 secs)
Then disconnect the power supply lead again.
Then Plug it back in again & turn on
It should be cleared & working well.
Good luck
Aug 10, 2013 | Sharp AF-S120FX Air Conditioner
We have an E1 code on our Sharp energy star model AF-S100FX air conditioner and the unit will shut off. What does the E1 code mean?
Display Codes:
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Jul 22, 2011 | Sharp AF-S100FX Comfort Touch Air...
I get an error code e1 and have cleaned and replaced the filter. Runs for a couple minutes then shuts of with same message. Any ideas?
THIS SHOULD RESET IT
1 DISCONECT THE POWER PLUG FROM POWER SUPPLY 2 CLEAN FILTER 3 HOLD DOWN THE POWER ON/OF BUTON ON THE UNIT AND PLUG THE UNIT KEEP PRESSING UNTILL IT EMITS A BEEP SOUND FOR APROX 5 SECONDS 4 DISCONECT POWER AND PLUG AGAIN
IF THAT DOES NOT WORK 1 DISCONECT UNIT 2 HOLD DOWN THE MODE KEY ON THE PAD OF THE UNIT AND PLUG THE UNIT KEEP PRESSING UNTIL IT EMITS A BEEP SOUND APROX 3 SECONDS THE UNIT WILL START. 3 STOP THE UNITS OPERATION BY PRESING ON/OF 4 RESTART UNIT.
BEST OF LUCK
May 31, 2011 | Sharp AF-R120FX 12,000 BTU Comfort Touch...
Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Jul 12, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
The alarm will not shut off after unit is turned on.
shut off for 5 minutes, and restart, if that does not work then youmay need to clean the filter in the back.
Jul 30, 2009 | DeVilbiss 5 Liter Oxygen Concentrator with...
"Cool" mode shuts off
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
Aug 03, 2007 | Sharp AF-S85FX Wall/Window Air Conditioner
Air condition problem
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The manual says to clean filter and unplug unit, then plug unit back in and code will be reset.
Aug 02, 2007 | Sharp AF-S120FX Air Conditioner
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
