Question about Dishwashers
Not filling with water
Dish washer has only been use once keeps showing a-3 time goes down lights on but no water going in
  • 6,784 Answers
HI. this is a water inlet valve issue. i recommend testing this device. it may be faulty.
To access the inlet valve remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel. The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow. There are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced. Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. If your valve has two solenoids, test the second one in the same way as the first. If the solenoid is working properly, but water leaks through the valve even when the dishwasher is off, then the valve itself is the problem. Debris may be preventing the valve from closing. If the valve cannot be cleaned, it will have to be replaced. The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Posted on Jul 28, 2009
Fills with water and drains does a few times goes thru complete cycle but washer never washs, water does not spray dishes. Soap dispenser opens.
1st check for food build up under the filter, just shine a flash light through the holes front left side at the edge of your filter. This area is the water intake for the wash arms.
Oct 25, 2013 | Whirlpool 24 in. GU3200XTP Built-in...
Washer just shuts down
If the washer is turning off mid cycle then the problem most likely has something to do with the draining or the filling.
First check the drain hose is not to far down the standpipe. If it is to far down then the water might siphon out during fill. The water would fill and drain at the same time. One cycle I would like you to try is the "Rinse Only" cycle. This is a simple, short cycle that should just fill once, drain and spin. If the washer will do this then the major components are most likely okay.
Make sure the water drains out and let me know if the drain pump is the source of the noise you hear.
Oct 19, 2012 | Washing Machines
Pump running continuously, Yes there was a drain pack, have emptied water, float switch clicks when moved with screw driver. Only one red light shows ( last cycle - pots ) what else can I do... James
What type of dishwasher do you have? Has your kitchen floor flooded? If it has. The tray under dish washer isn't water tight. Moisture creates some unusual problems. Some of newer dish washer the there control panel under the top of door this also create problem especially if the switches are on the top of the door. Another moisture problem. I have repaired a new Electrolux dish was three times in less than 6 months. The floor would flood from the Maytag side load washing machine. The Madam of the house didn't tell me that the washing machine flooded the kitchen floor. No window in the door and sometime fill water solenoid would stick and fill the tube. When they open washing machine door, 12 gallons of water would spill. So I fix both of them. GB...stewbison
Aug 21, 2011 | Asko Dishwashers
The cycle has finished and the dry light is on and it keeps beeping. Usually it beeps 8 times then all lights go off and cycle is finished. i ahev just filled it with salt but this has never happened...
ok why whoud you put salt in dish washer you screwed it up from doing that the salt sweld up and cloged the sencer the sencer is your intake and your intake takes water in out clean out with dish soap 1 or twice with mild water mixed with dish soap[
Feb 15, 2011 | Dishwashers
Is it normal for water heaters to drain out when there is no electricity?
If there is no electricity, it doesn't drain out, it just doesn't fill up. Unless you have city water. The Tank doesn't know if it has water in it or not, it just heats up no matter what, If there is no water it will burn out the elements on an electric heater. Your heater should not drain out at all, it takes hours to drain it when you have to, it just trickles out. If you have a problem with your heater being empty, It should have a 3/4 line going in, and the valve be open, of course, and all the sinks and faucets, washers, etc, should not be dripping, but like I said, it shouldn't leak or drip and stay full all the time. The only time you will dent the volume is when 3 people take showers at the same time and the washing machine is running and somebody is doing dishes in the kitchen. But when the power goes out, it doesn't fill up. So don't use any water when the power goes out. Now that you are totally confused, hope this helps.
Oct 31, 2010 | Water Heaters
Dishlex Global 300 starts to fill with water, then
ok this sounds like your water has stopped coming in or timed out b4 the pressure switch is activated. hold eco button down, u will hear a beep then a light will come up, keep pushing the button until u see the light.reply and tell me which light has come up, and i can help u fix the problem.
Apr 24, 2010 | Dishwashers
I have gritty debris on the dishes, it appears the small bits left on the dishes before loading get broken down and rinsed onto them as grit again! The dishes are not spotless going in but they are scraped...
1. it can be water backing upfrom maybe a garbage disposer like a clog ,or fill jet dry compartment completely.add nad fill then open and close the door 3 times then you will be able to add more what you are doing is taking out the air in the dispenser.once it is filled completely last thing is to make sure the water ghoing into machine is hot,then start the machine for best results. let me know if i have been of some help
Feb 24, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
No water spraying in washer, and no error code
Either:
1. not enough water gets into the dishwasher. open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
Good luck,
Vlad
First Choice Appliance
Jun 10, 2009 | LG LDF6810ST Stainless Steel Built-in...
Water keeps filling!!
sphion effect while the water comes in the water goes out ..because you never said that it overflows,,,so just put your drain hose up the height of the machine before it can go down,,,drain hose to low...onthejob
Nov 16, 2008 | Frigidaire FTF530FS Front Load Washer
Indesit D167. When cycle selected no water pumping or filling but 1 & 2 green indicators on.
Tilt your dishwasher forwards. Be aware that water will come out ouf the bottom. Once this is clear your washer should be Ok.
Good Luck
Sep 23, 2007 | Indesit 24 in. DI67 Free-standing...
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
