Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
KDF-60XS955 Blue Creep
I also have a slow lower right corner blue encroachment. It's getting bigger and now I have blue dots spreading across the screen. Is this the end or just an adjustment?
    President:
  • 563 Answers
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further
Posted on Jul 28, 2009
Small blue dots on the screen
Sounds like a DLP chip failing if thats the type of TV that is
Jan 15, 2014 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue dots on screen. Blue band on on/off side of screen.
blue dots on screen,bright blue haze right corner to north westpast center of screen.
May 24, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue dots and blue area on my screen
Your blue LCD panel is failing. It is within the Optical Block and the entire block must be replaced in order to repair this. Over time (usually a short amount of time) this problem while progress until the picture is bad enough that you will want it fix immediately. So, it's good that you are looking into this now :) Here is a PN for the Optical Block... PN: A-1084-668-A I hope this helps.
Mar 17, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
The lower left hand corner of the screen is turning blue
catually is problum is related with blue lcd & blue polizer but first you clean the optical unit if the problum gon then ok other wise must chang blue lcd & blue polorize with uv filter plese contect to your nearst sony service centre
Feb 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
There is a blue color invading the screen across the bottom and right lower corner and a cloud of blue developing on screen
trye to change on tube of screen hawe som resistors and 1 of transistor tere you kan meger it and you will se wich 1 need to swampe it.
Jan 23, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a permanent blue light encroaching the picture on the lower left corner of our sony kdf-60xs955 60". Replaced the bulb recently.
The Optical Block is probably the cause of the problem. I am not sure if it is still a Recall issue but due to the cost of the repair, I recommend you call Sony at 1800-222-SONY and see if they can assist
in the cost of repairs and also to help locate a Service Facility to confirm the symptom.
I hope this helps,
Skyassoc
Oct 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Large blue covering entire bottom right corner and blue dots
optical block failure call sony, they are a known fault on all rear pro sets from 2003-2007, they may replace for free, have extended warranty on this part.... there are lawsuits pending against sony over this problem
Sep 13, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
KDF-60XS955 Blue dots all over screen. Lower left corner of screen has a small blue cone shape. Will a new bulb fix this? If yes how do I replace the bulb?
It is problem of light engine (optical block) in TV and Lamp replacement does not solve it.
TV needs replacement of light engine, that is costly part.
Jun 20, 2009 | Sony KDF-42WE655 Television
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
266 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
