Question about Xerox DocuColor 12 Printer
Doc 12 printing lines.
Hey there,
our doc 12 is printing with a sort of corduroy effect on everything, especially light colors.
If you fan through the printed pages, you can see the lines move, rotate and grow.
This is coming from InDesign on a Mac, to the Fiery X12.
  • Rob Rodgers Nov 22, 2007
    Here is a picture.
    The lines don't seem to get along with the scanner, so there is also a rainbow effect in the picture that is not actually on the print
    and another pic.
    Problem Solver:
  • 8 Answers
Did you tried changing the print cartridge
Posted on Jan 10, 2008
How do i stop my sharp mx 4111n printer from printing with line on the paper
does this happen when printing? or copying? if printing check the fuser, image /drum unit What color is the line replace that image unit, if copying does it happen thru the doc feeder ? if so place on the big glass and make a copy if it goes away the its the doc feeder slit glass that is small glass use by the doc feeder, big glass not used by the doc feeder when copying or scanning
Feb 17, 2015 | Sharp Office Equipment & Supplies
How do I fix canon mx310 which prints with lines
please check doc. page setup, may be outline or outside margin resulting not space.
Apr 15, 2010 | Canon PIXMA MX310 All-In-One Printer
I have an HP Laserjet 2840 All-in-One that is displaying "low memory, press (check mark) to continue". I have done this several times but the Word doc still does not print. The Word doc has a large...
You want print a large file? you will get this problem.
1. divide your file to small printing jobs: example: 50 pages must be printed 4 times 12 pages.
2. Add memory.
3.If your problem continue contact HP support
you can also open this link:
Sep 11, 2009 | Office Equipment & Supplies
I need the diferences between docucolor 12 and xerox 7132? please
Pretty vague question.
The Doc 12 probably has a Fiery Network controller, while the 7132 has a Fuji/Xerox controller.
The Doc 12 would have limited scanning capabilities while the 7132 can, depending on the config ordered, scan to E-mail, SMB, FTP, Scan to PC, and scan to a mailbox on the Xerox itself. If you have an embedded fax in the configuration, you can set it to catch incoming faxes and forward to e-mail, or a SMB or FTP folder on your PC or server.
The 7132 is rated at 8 pages a minute in color mode, and 30 pages a minute b&w.
The Doc 12 has been around since 2002, the 7132 is about 3 years old and has been replaced by the 7232.
Jun 23, 2009 | Xerox DocuColor 12 Color Copier
Lines on doc wont print
you got a driver for this very rare printer now?
What you give her IBM proprinter II protocol?
Should be a Proprinter III type
Go download here:
Don't forget my four stars ;)
May 05, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Hello I have sorted the growling sound out with a shot of WD40 lube ,but have not sorted out wht the cyan does not print clearly any advice would be helpfull
Nov 14, 2008 | Epson AcuLaser C900 Printer
Dark edges
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty.
Does this happen when,
Using the Doc Feeder
When making copies from the Glass
Or when you print from a computer (assuming you print from a PC)
If you print something and this happens then it is inside the machine
Probably toner or developer dumping...
Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment...
One more test
If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Oct 25, 2008 | Sharp AL 1215 Black and White Copier
Doc 12 Error Code
You Have to Clean a litle square reflexive patch that is located on the IBT Belt.
Just remove the waste developer botle, turn the orange handle CCW, remove the 2 external screws of the IBT Assy and pull out the Transport drawer and IBT drawer. clean the patch reinstall and thats it.
Feb 14, 2008 | Xerox DocuColor 12 Color Copier
Canon MP730 stops printing midstream
Is the issue the same with a anormal text document or just with heavily colored docs? If the text doc gets printed fine, then it is an issue with print spooler and we might need to work on that. revert & lemme know
Aug 05, 2007 | Canon SmartBase MP730 All-In-One InkJet...
Xerox DocuColor 12 Printer Logo
188 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
