Question about Whirlpool WED5100SQ Front-Load Electric Dryer
Plug dryer in wall wont start
I bought a used whirlpool dryer when I got it home it wont turn on or work but the person I bought it from demo in his house dryer works fine. when I plug in my old dryer it runs, but when I plug in the one I just bought I get nothing. They both have the three prng plug so why is it the old model runs on the out let but the dryer I bought wont. Old dryer- Frigidare model number: FDE7970EW2 runs. Whirlpool model number Lec8858equ1 wont. I am at my wits end. Help!!!
    President:
  • 1,273 Answers
The most obvious thing to me is that the cord may have been loosened or damaged by the move, or the terminals in the machine may have loosened. Either test the cord on your "new" machine, or replace it with a known "good" cord. Wait a minute....you already have one of those....
Try it, it may be the very thing!
Regards, --W/D--
Posted on Jul 28, 2009
Whirlpool
I think your old plug is probably 120 and you may need to convert to 220. It's probably the wiring is probably 220 in new home? Or maybe not grounded properly. This is a job for a professional. If you think you know what you doing, we try to save a few dollars by doing it ourselves. But sometimes it is time to call the experts, before we cause more damage and cost us more money. Good luck!
Aug 27, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool dryer GGW9868KQ2 wont run; lights come on on control panel but wont run when you press start; cliking noise when you press start. thanks
  • If your Whirlpool dryer will not run, there may be several reasons why. The first thing that you should do is check to see if you have either blown a fuse if you have a fuse box or check to see if your circuit breaker has been tripped. If this is not the problem, check to see if you can read 240 volts by the wall plug using a voltmeter. You should also check to see if the wires next to the power cord are burned at the point where they connect to your electric dryer.
    Check to see if there is a connection through the door lever switch and whether the lever switch clicks and connects when the door is closed? You should also look to see if there is a belt switch by the motor. If so, this could result in the dryer not being able to run if open.
Jun 04, 2011 | Whirlpool GGW9868K Gas Dryer
My Whirlpool electric dryer does not shut off when a load is done. The door must remain open in order for the dryer to stop. Other than that, the dryer works perfectly. Is it a switch or the timer or...
Pull the dryer out from the wall and take the vent hose OFF it is in the back, and then try it on auto-dry with no clothes in it and see if it runs through fine if it does not turn off then a new timer should fix it. Good Luck Tim. here is a website that will help click on timer motor, or you can use the virtual repairman:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Dec 23, 2010 | Whirlpool Dryers
Our whirlpool Duet dryer has three prong plug and home has four prong outlet. Do we change the cord or the outlet?
You should change the plug at the wall. From your description, your dryer plug has two hot wires and a ground.
Your existing plug probably has 4 wires to it - two hots (120 volts each), a neutral (white), and a ground (green). The two hots are probably black or black and some other color.
You will need to match the plug on your dryer cord with the plug at the wall. The type of plug required should be described in your owner's manual. If you don't have that, then take a digital picture of the plug on the cord of your dryer and bring it to your local hardware or home improvement store. They should be able to match the companion wall plug for you.
Make sure the power is off (important). Remove the existing wall plug. When you wire it back up - this time with only three wires, connect the two hots (black and some other color) to the two hot prongs (terminals) and the green wire to the ground prong. Put a wire nut on the end of the white wire and tuck it back into the connection box. That's it. Turn the power back on and test for proper voltage and wiring configuration at the wall plug before you plug the dryer back in.
If you aren't familiar or comfortable with working on electrical apparatus, you should have a licensed electrician do this work for you. This solution also assumes you are in the USA.
Jan 01, 2010 | Whirlpool GEW9250 Electric Dryer
Elec. in garage went out, heat from dryer didn't go on
Check the wall plug voltage for the dryer outlet with a voltage meter. The two holes on opposite sides of the wall outlet should read around 240V. Either of the two outside holes to the middle hole shoul dread about 120V. If your readings differ from these it's likely you have a problem with the fuse/breaker associated with the dryer or the person who fixed your heat made a wiring mistake.
Oct 03, 2009 | GE DBXR463GB Gas Dryer
Dryer wont start - no lights
Dryer door does not think it is closed. There is a sensor on the top of the door that is probably not making contact with the door. Trying pushing the top part of the door and holding it then press the start button.. if the unit starts running then you know what it is. I just had one of these dryers delivered today and had to find out about this by myself tonight!!
Apr 30, 2009 | Whirlpool WED9500T Electric Dryer
New whirlpool dryer duet steam wont work
Sound like the unit doen't know the door is closed the door switch is not working. does the light inside the drum come on when the door is open and off when the door is closed
Mar 29, 2009 | Whirlpool WED9500T Electric Dryer
Washer not working
at you home circui breaker...then the wall plug... then the timer switch ...then the motor and the door swich.
Mar 08, 2009 | Whirlpool LTE5243D Top Load Stacked...
Microwave wont heat
The manual says "while in standby mode, press and hold the '3' key on the keypad for 3 seconds until 2 tones sound and the 'DEMO' icon appears. Repeat to turn demo mode off."
You can download a copy of the manual here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208206572.pdf
Jan 13, 2009 | Whirlpool MH7140XF Microwave Oven
Dryer wont work!
A couple suggestions: (1) The switch in the front may be bad. It's the switch that turns the dryer off when you open the door. (2) Make sure the door latch keeps the door shut. If it is worn and the door isn't shut tight, the switch will not let it start. Hope this helps.
Oct 15, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool WED5100SQ Front-Load Electric Dryer Logo
148 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
