Question about Maytag M7DH45B2A Dehumidifier
Wont Work When I set the desired humidity level, the dehumidifier does not seem to follow instructions. For example, if I set it to 45%, it will work when its below that value and above that value. Sometimes, it will choose not to work at all. I tried unplugging it and plugging it back in, and I also played with all the buttons on it. What else could i do to troubleshoot? Please email me back at
  • 225 Answers
Re: Wont Work
If you haven't done so already, try removing and cleaning the inlet filter screen which is almost certainly just behing the inlet grille. If this is blocked with fluff then no moist air will get to the cold pipes, so little or no water will be extracted. There's also a chance that the humidity sensor is clogged with fluff, so fooling the system into thinking the room is pretty dry.
Hope this helps. If this "fixes ya", I'd appreciate a rating for my reply, If not, please delay the rating and add a comment with any extra info you have and I will try to think of something else.
Posted on Jul 13, 2008
0 characters
3 Points
Why wont it turn on?
if power is applied then display should show current room humidity , if set is pressed then display should show current set point for desired room humidity , this has to be less than first display otherwise the control will think room has acheeved desired setpoint and shut off , the one of these i had seemd to have an overly sensative collection bucket full sensor and had to be "just right" for unit to run
Feb 17, 2015 | Haier 45-Pint Dehumidifier
Model DE45EJ-L Fan works , does not take humidity out of the air
clean the dust off of the condenser in the front or the filter if it has one. no air flow results in overheating and no condensation across the evaporator coil.
May 07, 2012 | Haier 45-Pint Dehumidifier
Cannot set humidity level to anything other than 50.
Is it reading the room humidity, rather than showing the set point? Check the manual.
Apr 21, 2012 | Soleus DP14503 Dehumidifier
Everything seems to be working although I've set the humidity level at 50 but container still dry and humidity level still remains at 70. I trouble shooted everything per manual by cleaning filter...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
May 26, 2011 | DeLonghi DE500P Dehumidifier
My humidifier dont collect water
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
May 16, 2011 | Maytag Dehumidifiers
My dehumidifier compressor runs and then shuts off, then runs and shuts off, continuously. The fan continues to run. It seems to be pulling water, though it's hard to tell how much because I have a...
Part of the problem may be that you have the humidity level set to high. The fan runs constantly to move the air around. When the unit senses a humidity level higher than what you have it set for, the compressor turns ON. Once it's ON, if the humidity level is short lived, it turns OFF.
Try setting the humidity level to the lowest possible setting. Usually, that 45%. If the humidity level in you home is higher than that, the compressor should turn ON and run until either the bucket is full or the humidity level reaches 45%. If this doesn't solve the problem, turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet for 12-15 minutes. Plug the unit bakc in, turn the Master ON/OFF Switch to ON and set the humidity level at it's lowest setting. Allow the unit to run until it cuts OFF and check the bucket for water. Hopefully that 12-15 minute time out allowed the unit to reset itself.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 11, 2011 | Maytag M3DH30B2A Dehumidifier
I have a Goldstar Dehumidifier, model # GHD30y7 (S No 611TADR26946). It has worked well for a couple seasons. This season it will not stay running. It cycles on but shuts off after a couple minutes. I have...
Kreston, check the humidity level you have it set on. It may be that there is not enough humidity in the air for what you have it set on and it automatically shuts OFF.
Keep in mind, whatever level (percentage) you have it set on, is what it will maintain, not remove.
For example - if you have it set on 65%, that's pretty high level of moisture/humidity. But, it's not how much it's going to remove from the household air. Unless, the humidity level rises above 65%. Then it will only remove enough to maintain 65%.
If you want to remove humidity/moisture, you have to lower the setting below 45 to 50%, Try that and I think you'll meet with success.
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Goldstar DH304 Dehumidifier
Of our three 54501 Kenmore dehumidifiers, none produced water after two - three weeks. They run but no humidity is drawn out of the air.
Keep in mind, that a dehumidifier only draws humidity from the air, if the level of humidity is higher than what the controls are set on. For instance, if you have the dehumidifier set on 65 to 70%, that's a high level of humidity to maintain in a house. If you have it set for 35 or 45%, that's a low level of humidity to maintain in a house. Which, generally is what you want to maintain in the hot, humid summer months. I find it uncanny, that all 3 units are not collecting any water. So, it may simply be the case, that the humidity level on each unit is improperly set.
Also, a dirty air intake filter makes the unit strain to keep up and can't take in moisture as it should. So, if you haven't cleaned the filters on a regular basis, not is the time to do so. And while your at it, clean the cooling coils too.
The easiest and best way to test a dehumidifier at home, to see if it's working properly. Is to place it in the bathroom and turn the shower ON and don't operate the bathroom's exhaust fan. Set the humidity level low (45%), turn the unit ON and close the door when you leave. Wait 30 to 40 minutes and check the water collection bucket. If there's water in it, it's working as it should.
Hope this helped you to solve the problem. Please let me know.
May 03, 2011 | Kenmore 54501 Dehumidifier
Can't get down to the targetted humidity level
May 05, 2010 | LG LHD45EL Dehumidifier
Maytag M7DH45B2A Dehumidifier Logo
127 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Daniel Phillips
Daniel Phillips
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
