Question about O2 Samsung SGH-E250 Cellular Phone
What is JSRs trace?
Samsung E250 after entering *#52828378#.. displays java test menu... in that 5th option JSRs trace.. consists of Jsr120,Jsr75
Message lock password
SECRET CODES FOR SAMSUNG STAR 3g s5233 samsung, samsung 3g
Ok, here are all the codes you need to make sure you phone is working like it should.
The codes are keyed in using the Keypad.
*#06# Displays your IMEI
*#78# Test touch configurations , Sort of an Admin menu.
*#03# Displays a Unique number, specific for your phone I guess.
*#7465625# Phone lock status
*#232337# Bluetooth MAC Address
*#1234# Software Version running on your phone.
*#2222# Hardware Version of your phone.
*#0228# Displays battery information.
*#0289# Melody test
*#0782# Displays the real time clock of your phone.
*2767*2878# Displays a Service menu.(seems like it contains all the goodies :D )
*2767*3855# Beware: This code performs a full reset. Use it only when you are screwed up.
*#0842# Vibration test
*#0*# Speaker & LCD display Tests
Going through pages looking for a way to put Java applications directly from the PC into
my Samsung GT-S5230, I found this code to access admin settings (*#6984125*#),
it has a lot more options than the codes you provided, including "Internals",
which enable the user to update Java and applications database, however,
when you try to access this option, a master key will be requested,
and you must enter the following code, *#9072641*#.
goodluck i hope can help you
Jul 06, 2014 | Samsung Star GT-S5233 Cell Phone
Tip
SAMSUNG TIPS
Samsung Secret Codes
Software version: *#9999#
IMEI number: *#06#
Serial number: *#0001#
Battery status- Memory capacity : *#9998*246#
Debug screen: *#9998*324# - *#8999*324#
LCD kontrast: *#9998*523#
Vibration test: *#9998*842# - *#8999*842#
Alarm beeper - Ringtone test : *#9998*289# - *#8999*289#
Smiley: *#9125#
Software version: *#0837#
Display contrast: *#0523# - *#8999*523#
Battery info: *#0228# or *#8999*228#
Display storage capacity: *#8999*636#
Display SIM card information: *#8999*778#
Show date and alarm clock: *#8999*782#
The display during warning: *#8999*786#
Samsung hardware version: *#8999*837#
Show network information: *#8999*638#
Display received channel number and received intensity: *#8999*9266#
*#1111# S/W Version
*#1234# Firmware Version
*#2222# H/W Version
*#8999*8376263# All Versions Together
*#8999*8378# Test Menu
*#4777*8665# GPSR Tool
*#8999*523# LCD Brightness
*#8999*377# Error LOG Menu
*#8999*327# EEP Menu
*#8999*667# Debug Mode
*#92782# PhoneModel (Wap)
#*5737425# JAVA Mode
*#2255# Call List
*#232337# Bluetooth MAC Adress
*#5282837# Java Version
Type in *#0000# on a Samsung A300 to reset the language
Master reset(unlock) #*7337# (for the new samsungs E700 x600 but not E710)
Samsung E700 type *#2255# to show secret call log (not tested)
Samsung A300, A800 phone unlock enter this *2767*637#
Samsung V200, S100, S300 phone unlock : *2767*782257378#
on Sep 27, 2010 | Cell Phones
I have samsung champ gt-c3303 .It cannot run any java supported file what can i do for it ?
Just place a jar files(games or apps) on a memory card. Then just click on the apps or games it will install. Samsung champ will only install below 500 kb/apps or game, if you want to install higher than that just used this code by dialing *#52828378# you will go to Java Test Menu, then go to OTA test, change 500 to 4000 then save. You can now install as much higher than 500 kb but less than 4 mb.
Oct 05, 2010 | Cell Phones
Installing java games to SAMSUNG E250
I finally succeeded in installing some java games to my Samsung E250 via bluetooth. I thought I would share the info on how I do it here because it seems to be a frequent unanswered question on various forums. You will need a *.jad and a *.jar file for your game. 1) Download Softick PPP and Samsung Java Uploader.exe . Also JADmaker if required. 2) Install SoftickPPP according to this Polish website. I don't understand Polish, but the pictures tell enough of the story. Set up your bluetooth COM ports in the SoftickPPP bluetooth/serial settings. My Bluetooth COM ports are either 24, 25 or 26. I leave them all ticked. 3) Enter *#52828378# on the phone to access the Java Test Menu. Choose OTA type setting, choose Serial bearer OTA. Click select. (This seems to need to be changed back to GPRS bearer OTA for Samsung PC Studio to connect) 4) Start SoftickPPP. Click on cancel for the missing USBPort.dll error message. Accept bluetooth connections for DUN and Serial connections on the phone. 5) Choose 'Activate PPP' by right clicking on the icon in the taskbar. Accept connections on phone again. 6) Start 'Uploader.exe' and then add the required jad file. Leave the program open. 7) If you are not still in the Java Test Menu then enter *#52828378# on the phone again. Select 'Serial test', 'PPP Up', 'Bluetooth' on phone, 'Serial download'. My phone sometimes restarts at this point in which case I have to choose 'Shutdown PPP" in the taskbar icon and then re-activating it once the phone has restarted and then re-do step 7 after entering the Java Test Menu again. A Java splash screen should appear with a progress bar showing the upload of the file. The game then starts automatically. There we go. It works for me Please man do you speak bosnian..
.Quote:
1) Type in the code *#9998*52824678255# (which reads *#9998*JAVAINSTALL# )
2) Your phone should return with 'Activated'
3) Now using Bluetooth or USB cable, connect to your phone (IR probably works too)
4) If you have a game as .jar, but don't have a .jad file, use JadMaker to create one (draw the .jar file to it and it will generate a .jad file for you).
5) Copy the .jar AND .jad file of the game into the map called "Other Documents" on your phone.
6) Now on your phone under 'My Files' browse to the 'Other Documents' map and doubleclick on the just copied .jad file.
7) The phone will ask you if you want to Install the game.
8) After Install you will find the game under Games on your phone.
9) You can now remove the just copied .jar and .jad file again (they were only there to install the game onto your phone).second answer:that i go to samsung company and when i ask them about jave install on samsung they say to me that the only way is to download from mobile internet games but it will be triall expet a game called 4*4 extreme race only and i tried to install any game it will be trial thanks for your reading (trusted)
May 22, 2009 | Samsung SGH-E900 Cellular Phone
How i can install java games in samsung sgh e250 via card reader problem:
I got a beautiful answr on d net surfn 4 yr questn ...
.Quote:
May 22, 2009 | O2 Samsung SGH-E250 Cellular Phone
Application intaller on samsung E250
Programs I've Used:
IVT Corporation BlueSoleil
Softick PPP - I've left all COMs ticked
1. Turn on you're Bluetooth
2. Open your Samsung Java Uploader and add your desired Java Game.
3. Open the Softick leaving all COMs checked.
4. Go to Phone Settings > USB Settings > Choose Mass Storage
5. Key in *#52828378*
6. Make sure the OTA type is in Serial Bearer OTA
7. Click Serial Test then click PPP UP
8. Choose Bluetooth
9. Open the IVT Bluetooth Program that I've mentioned above and activate Bluetooth Serial Port Service
10. Finally, click Serial Download....
Ta-dah!
NOTE: After a download, you need to do the steps all over again as they go back to the default settings...
pls vote me  thank you
Feb 13, 2009 | O2 Samsung SGH-E250 Cellular Phone
Problems on games in samsung e250
To Install Java Games On Your Samsung-E250,You Have To Download "Softick" PPP and A "Java game Uploader"(search it on Google)..........
lnstall java games using usb data cable
SAMSUNG E250
Install\Run SoftickPPP221 from the Softick.PPP.v2.21 Folder. Ignore any errors about usbsync.dll by pressing OK.
Leave the option use usb in shared mode checked.
Run when finished installing. You will get an error message about being unable to locate usbport.dll, just click cancel.
Plug in your usb cable and turn phone on.
Right click on softickppp running in your taskbar and select settings.
In the usb tab uncheck accept ppp connection on usb and tick both use usb in exclusive mode and overide usb compatability,
Click on ok and completely exit softickppp by right clicking then exit.
Run softickppp and again goto settings. On the bluetooth\serial tab tick the correct com port.Mine is com3. Then click ok
On your phone key in *#52828378# press 2 ota type setting and select serial bearer ota.
Run samsung java uploader and add your jad file
On your phone select 3 serial test , 1 ppp up , 2 usb
Your phone will now reboot. While its rebooting right cklick on softickkppp in your taskbar and choose shutdown ppp
When your phone has rebooted again key in *#52828378#
Right click softickk ppp and activate ppp
On your phones java test menu press 3 serial test , 1 ppp up , 2 usb , 2 serial download
Your game should install and start running.
Oct 15, 2007 | Samsung SGH-E900 Cellular Phone
How to install games in smg e250
1) Download SoftickPPP and Samsung Java Uploader.exe from here. Also JADmaker if required.
Aug 16, 2007 | Samsung SGH-E900 Cellular Phone
Unable install games in samsung e250
Aug 04, 2007 | Samsung SGH-E900 Cellular Phone
O2 Samsung SGH-E250 Cellular Phone Logo
128 people viewed this question
Top O2 Cell Phones Experts
Computer Repairing
Computer Repairing
ivan georgiev
ivan georgiev
Are you an O2 Cell Phone Expert? Answer questions, earn points and help others
