Hi clausen minerva optiduel started measuring temp in F not celcius last night have tried & read everything but cannot find solution???
3 Suggested Answers
  • 3 Answers
SOURCE: I can't change the temp. reading from celcius to regular temp.
Check the manual, you have to hold down Ambiant and the Temp Up button for 5 secs or something.
Posted on Feb 04, 2009
honeymokey
  • 3113 Answers
SOURCE: Hi, tried to start my car this morning, it was -30
Remove all of the cables from the battery and clean them and the battery connector , replace bolts.
Posted on Mar 24, 2010
Turbo air maximum ref MSR-49NM goes to minus freezing temps everything has been cleaned unplugged for 24 hours. worked for 2 weeks went to minus temps again last night
In generic terms, it is either the temperature controller or the sensor that reads the temp and sends that to the controller. Something is no telling the compressor to turn off.
Oct 01, 2017 | Turbo Air Refrigerators
The disc starts to spin then stops?
If the player is not able to spin the disk up to full speed in X amount of time the default is to shut down.
So most likely you need a new player.
But first try unplugging the power to the player for one minute to reset it then plug it back in. & give it a try.
next it might be getting to hot maybe dust buildup at vents or placed on top or too close to something that makes heat.
Again unplug & let it get to room temp maybe over night then try it again.
Lastly you could try a lens cleaning disk. Maybe the lens can't read the disk & this is causing it to stop trying & stop spinning. This is a long shot as if it's a read fault it should display that message.
Sep 20, 2015 | Televison & Video
Coils freeze and temp says it is 55
Low on refrigerant or low airflow. The temp sensor is reading the ice.
Jul 20, 2012 | Whirlpool Heating & Cooling
2004 E150 van wont start. -5 degrees last night, battery is less than a year old and tests out OK according to NAPA test. When key is thrown, just a click is heard. Dash volt meter reads normal,...
START BY CLEANING THE BATTERY TERMINALS. NEG CABLE OFF FIRST THEN POSITIVE. CLEAN CABLES & TERMINALS PUT CABLES BACK ON & TIGHTEN POS. FIRST, NEGATIVE ON LAST & TIGHTEN. IF THAT DOESN'T DO IT. LOCATE STARTER RELAY ON FENDERWELL. TURN KEY TO START. MEASURE VOLTAGE AT STARTER RELAY. IT SHOULD READ NEAR 12 VOLTS. IF NOT CHECK NEUTRAL SAFETY SWITCH. THE STARTER MAY BE STUCK OR WORN AS A LAST RESORT HOLD IGNITION SWITCH IN START POSITION, AT THE SAME TIME TAP ON METAL PART OF STARTER WITH MEDIUM SIZE HAMMER. IF STARTER GOES AFTER HAMMER TEST, REPAIR OR REPLACE STARTER.
Jan 21, 2011 | 2004 Ford E150
Dishwasher will not turn on. Last night I started
You need to measure with a voltmeter for 115 Volts at the electrical box under the washer front. Breakers can fail, yet look ok. This will check the breaker output and all of the wiring in between. There may also be a local circuit breaker that tripped.
Aug 18, 2009 | Dishwashers
Sonata coolant temp at 61C at thermostat opening
If your positive that the reading is from coolant after the thermostat opens & on the return side of thermostat, as in flowing toward or into radiator, then that is too low. 61C/142F is too cool, even in summer. It should be coming out around 82C-90C.(180F-195F) I'd double check that reading and make sure it's coming from the discharge side of thermostat, and if it's correct, replace it with an 82C/180F thermostat, as this is what is recommended for 2.4L engine, but call Hyundai on the 3.3.L engine, as I am not getting a listing for thermostat on 3.3.L. Also keep in mind that during winter, your AC compressor is kicking in anytime your on defrost, as well as your normally running with heater on as well, if not defrost, which all contributes to lower gas mileage, add more fuel to get engine started when cold, and it will suffer some, but if running too cold, certainly will throw that all off as well.
Aug 11, 2009 | 2006 Hyundai Sonata
Door left open, now fridge won't work right.
Shut down the fridge for 10 - 15 Minutes and leave the fridge door open, and push the Defroce button
ANd start the fridge again and after some time check the temp.+ after some time.
Thanking you,
Your Tech Support
Manish Shirsikar,
Fixya.com
May 18, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Jan 15, 2009 | 2002 Hyundai Santa Fe
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
